Fluctuating idle on 1995 accord ex
Old Mar 8, 2004 | 05:14 PM
95ACEX's Avatar
Default Fluctuating idle on 1995 accord ex
I searched the accord forum for a thread on this but I could no find one. Ever since the beginning of the winter, after I installed my intake, my idle has been fluctuating when the car first starts in the morning, or when I'm at stoplights, etc. It seems to idle between 1500 and 2000. Could this be because of the fact that one of the plugs is not plugged into my aftermarket intake? I have talked to other people that have had the same problem, and no one has come up with a solution. I know you all are very knowledgeable, so I'm hoping I can solve this problem once and for all. Thank you in advance.
Old Mar 9, 2004 | 04:34 AM
95ACEX's Avatar
Default Re: Fluctuating idle on 1995 accord ex (95ACEX)
ttt
Old Mar 9, 2004 | 04:49 AM
Filthy Focker!'s Avatar
What plug is not plugged in your intake?????
fs
Old Mar 9, 2004 | 06:32 AM
jagged4698's Avatar
Default Re: Fluctuating idle on 1995 accord ex (filthy_shovel)
Its the idle enhancement valve. It is inside your throttle body and coolant runs through it telling your ecu when its warmed up. Your car goes up to 2000 because the ecu thinks its cold but then it reads its warm because the valve is faulty and responds at the wrong times. It cost me something like $300 to have it done at a shop. I'm pretty sure the air intake has something to do with it.. you can keep your current air intake just replace that valve
Old Mar 9, 2004 | 06:34 AM
ForceThis!'s Avatar
sounds like a vac leak to me
Old Mar 9, 2004 | 06:38 AM
Default Re: Fluctuating idle on 1995 accord ex (ForceThis!)
Little reminder here.. .If your car came with certain connection or plugs that were plugged into the OEM parts you replaced, you have to plug them back in. If not, something is going to malfunction....
The 'plug' you are talking about is not there for nothing.... If your aftermarket intake has no place to connect this plug, then you either have to get the correct intake or try to macgiver it somehow (not recommended)
fs
Old Mar 9, 2004 | 06:49 AM
95ACEX's Avatar
300 is steep for a minor annoyance, the car runs fine otherwise. Will leaving it like this have any adverse affect on my car? I plan to replace my tenzo air intake with an AEM at some point, so I'll have a place for the plug.
Old Mar 9, 2004 | 07:05 AM
I don't believe so, only driveability issues...
fs
Old Mar 9, 2004 | 08:41 AM
95ACEX's Avatar
Thanks, I guess I'll live with it.
bestofthe80s
May 7, 2017 05:21 PM
nrmskate
Sep 10, 2013 08:28 AM
DeloresElizabet
Oct 7, 2012 03:09 PM
mikeycivic
Jun 7, 2012 12:09 PM
shadetree14
Sep 20, 2009 09:16 PM
