H22a Throttle Body vs. B16a Throttle Body.
Old Mar 8, 2004 | 04:43 PM
jedubz's Avatar
Default H22a Throttle Body vs. B16a Throttle Body.
Well last time I dyno'd my car it put down 161whp 125 ft lb tq.
(b18a/b16a ls/vtec)
That was before GSR cams, got my TurboEdit "Fuel Management", and now tommorow I'm adding an H22a throttle body.
I have no real intake set up, I'm just running open throttle body with a nylon over it until I can afford to relocate my huge as hell optima battery. (BTW I drive a CRX so intake set ups are really hard to cram in there when you've got a B-series)
I believe the b16a1 (which is most likely what I have since it's a JDM b16a1 head) is 58 mm and the H22a is 60mm.... I'm wondering..
1) what all will I need to change? I've heard something about coolant lines, vaccum lines, throttle cable? I'm really in the dark because some people say nothing, some people say lots.
2) Any noticeably power gain here? I'm not asking for much since I'm getting it for a straight trade for my b16a one so it's basically free power (if it does infact make power).
Old Mar 8, 2004 | 06:08 PM
junbb1's Avatar
Default Re: H22a Throttle Body vs. B16a Throttle Body. (jedubz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jedubz &raquo;</TD></TR><TR><TD CLASS="quote">Well last time I dyno'd my car it put down 161whp 125 ft lb tq.
(b18a/b16a ls/vtec)
2) Any noticeably power gain here? I'm not asking for much since I'm getting it for a straight trade for my b16a one so it's basically free power (if it does infact make power).</TD></TR></TABLE>
you do realize you are loosing a quite bit of power running with no intake arm. i know that the h22 has the fast idle valve bolted to the bottom of it and you will need two coolant lines for it.
Old Mar 8, 2004 | 07:22 PM
jedubz's Avatar
Default Re: H22a Throttle Body vs. B16a Throttle Body. (junbb1)
Yeah, I realize the power loss... But you should seriously see this sheeyot!
And that's with the SMALL battery. Thats like 1 inch inbetween the battery and the strut bulge. Once I relocate battery to the rear I'm going to be custom fabbing an intake... Already started a bit. I'll post pics someday.
Old Mar 9, 2004 | 07:05 AM
Lip's Avatar
Lip
can you plumb the intake arm down instead of forward?
Old Apr 15, 2004 | 06:18 PM
Phillip4288's Avatar
Default Re: H22a Throttle Body vs. B16a Throttle Body. (Lip)
Yes its possible.. Pretty tough to do but its possible . good LUCK!
Old Apr 19, 2004 | 02:31 AM
hksbigboi4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junbb1 &raquo;</TD></TR><TR><TD CLASS="quote">
you do realize you are loosing a quite bit of power running with no intake arm. .</TD></TR></TABLE>
not very smart.. letting dirt n **** all up in the intake...
Old Apr 19, 2004 | 09:53 AM
JDMorgan's Avatar
b20 and itr are 60mm too....itr even tapers out to 62mm on the outside.
Old Mar 1, 2005 | 11:55 PM
GOLDBERG's Avatar
Default Re: (KraZEtEggIE)
isnt itr tapered too 64 and 62 on the inside...
702accord
Aug 10, 2009 03:45 PM
ItzTw
Feb 21, 2007 09:38 PM
JDMcivicRacing
Aug 5, 2005 01:59 AM
