B18B vs. B18A crank
Old Mar 8, 2004 | 04:37 PM
RAS Motorsports's Avatar
Default B18B vs. B18A crank
I have a gsr that i spun a bearing on, and i want to do a COMPLETE rebuild.. Everyone telling me to throw in an LS crank with LS rods on gsr pistons...now my question is...is there any difference in these 2 cranks? i can get a good deal on an B18A...but it has 100+ miles on it...will i have to end up doing extra to the crank to extend life? (micropolish...etc..)
Old Mar 8, 2004 | 04:44 PM
nickgmiller04's Avatar
Default Re: B18B vs. B18A crank (95GeeZR)
if you have a gsr, then the ls cranks are different. the ls has a 89mm stroke and i dont know what the gsr stroke is cuz i dont have one. but putting the ls crank in the gsr block will essentially give you a ls/vtec and probabaly wont take the revs as well as the gsr.
i think cranks really dont go bad, the bearings or whatever do and need replacing.
dont take this as the bible of engine building tho. my b18a is still stock
Old Mar 8, 2004 | 04:45 PM
Default Re: B18B vs. B18A crank (nickgmiller04)
but is the b18b and b18a any different in cranks?
Old Mar 8, 2004 | 04:56 PM
SkRiBLaH's Avatar
no...
Old Mar 8, 2004 | 05:55 PM
riceball777's Avatar
no differance at all between a b18a and b18b crank
Old Mar 9, 2004 | 12:33 PM
Default Re: B18B vs. B18A crank (riceball777)
ok...well...wha can i do with my crank with the spun bearing? can i micropolish it and it'll be like brand new? wha else could i do to it?
Old Mar 9, 2004 | 03:38 PM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GeeZR &raquo;</TD></TR><TR><TD CLASS="quote">ok...well...wha can i do with my crank with the spun bearing? can i micropolish it and it'll be like brand new? wha else could i do to it?</TD></TR></TABLE>
Depends how bad it is. Take it to a machine shop and have it checked out. If you do have it polished out make sure you get the right bearings as you will more likely need a different size than what the markings on your crank and block say.
Old Mar 10, 2004 | 03:08 PM
Default Re: B18B vs. B18A crank (arw321)
o yea...does it matter if i use a crank from an automatic? everything should still work fine, correct?
Old Mar 10, 2004 | 07:57 PM
ferio 95's Avatar
cranks are the same auto or manual being that its from the same motor ls si gsr etc
Old Mar 11, 2004 | 12:18 PM
Default Re: B18B vs. B18A crank (ferio 95)
i also heard that if you put in an ls crank with ls rods on gsr pistons...that you could rev up to 9000rpm safely...is this true? and how could it be if both motors stock can only rev up to 8 at most?
Old Mar 11, 2004 | 03:33 PM
i dont think it would be safe to rev to 9k w/ ls crank and stock rods. pistons dont really effect the safety of high revving. but again im not an engine expert, just what i beleive i have know.
Old Mar 11, 2004 | 03:38 PM
anybody know for sure?
Old Mar 11, 2004 | 04:59 PM
thats why ls/vtecs arent that safe at high rpms. the ls crank and rods. maybe w/ forged rods and balanced crank.
they would work in a gsr block, but i think essentialy youd have an ls/vtec w/ oilsquirters and high revs wouldn't be safe
Old Mar 11, 2004 | 08:49 PM
ferio 95's Avatar
its the head what determines if it can rev to 9k. dual valve springs titanium blah blah blah and its not a problem but arp bolt studs would be a big help. But the oil squirters are key get forged parts if you can afford to get those put in your block cause the oil cools he pistons. the heat cause the rds to expand and toss when they dont have squirters on high reving engines
Old Mar 12, 2004 | 03:26 AM
right. the head and bottem end need to be built for 9k if your going there. i dont think the ls bottom end will handle 9k well.
and hes got a gsr block so oil squirters are already there
Old Mar 12, 2004 | 06:42 AM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 &raquo;</TD></TR><TR><TD CLASS="quote">its the head what determines if it can rev to 9k. dual valve springs titanium blah blah blah and its not a problem but arp bolt studs would be a big help. But the oil squirters are key get forged parts if you can afford to get those put in your block cause the oil cools he pistons. the heat cause the rds to expand and toss when they dont have squirters on high reving engines</TD></TR></TABLE>
It's not ONLY the head that determines how reliably the motor can rev. Rod stroke ratio, how well your bottom end is balanced, etc. I've seen a lot of spun rod bearings on "high revving" LS motors because of stretched rod bolts. IMO, ARP rod bolts are 100% necessary.
Dave_Dc2
Oct 21, 2008 10:38 AM
TylerC
Oct 4, 2004 06:10 AM
delslow94
Mar 21, 2003 05:28 AM
delslow94
Mar 17, 2003 08:41 PM
delslow94
Mar 17, 2003 06:27 PM
