LS owners and rev limit..
Old Oct 17, 2001 | 11:05 AM
b18bvudoo's Avatar
New User
Default LS owners and rev limit..
when you're near the rev limit, ~6k rpm and up, do you hear a hissing sound from the engine? its loud enough for me to hear over my cai.
Old Oct 17, 2001 | 11:07 AM
lsvtec's Avatar
New User
Default Re: LS owners and rev limit.. (vudoo666)
From in the car, no. When I open the hod and rev the car I can hear the intake hiss.
Old Oct 17, 2001 | 11:12 AM
Johnny62's Avatar
New User
No hissing sound here. Does the sound you hear sound like air?
Old Oct 17, 2001 | 11:20 AM
b18bvudoo's Avatar
New User
Default Re: LS owners and rev limit.. (Johnny62)
i know how a cai is suppose to whistle, but this sound is more like, i dont know, a high pressure spray? thats the best i can do. only thing in the engine now is a cai.
Old Oct 17, 2001 | 11:23 AM
b18bvudoo's Avatar
New User
Default Re: LS owners and rev limit.. (booster)
Before i did my motor swap i had AEM CAI and in high RPM's it made a hissing sound. That is normal i suppose.
yeah thats what i was thinkin cause before the cai was in, the hissing wasnt there. i'm not really worried about it tho; everything looks fine under the hood.
Old Oct 17, 2001 | 11:43 AM
maxxdout's Avatar
well there are a few things that might cause it.
first, the CAI, tends to make a whistleing noise at a certain point. It has to do with TB position. At a particular throttle level, the air traveling past the TB valve reaches a velocity that as it passes through the TB caues the air rushing over it to produce a resonation or the whistle.
second, at higher RPM, your LS valve guide retainers ( i think thats what they are called) tend to loosen themselves. Not alot, infact very little. But once the valvetrain reaches the higher RPM levels the rapid movement of the rocker arms causes the slight movement that would result in a highspeed rattle. Nothing bad, just common.
hope that helped some
phylum
25
Apr 26, 2003 11:21 AM
Ideal R
Apr 2, 2003 07:25 AM
FUtUreAccOrd
Nov 2, 2002 08:53 PM
acatak
Jul 23, 2002 08:22 AM
Zulu888
Sep 26, 2001 04:37 AM
