Pics of my 10-94 header and kteller exhaust
Ok guys nothing detailed but just figured id show ya some pics of my new setup.
98 integra, 10-94 compact header, 2.5" cat 2.5" piping and a magnaflow oval 2.5" muffler
overall it sounds awsome.... deep growly sound... power gains seem pretty good (no dyno yet) i know i had to raise my fuel pressure up about 8 psi or so. i weighed my car before and after there seems to be about a ~30-40 lb difference (had slightly different amounts of gas).
only negatives are the ground clearance. i had to raise my car up a bit so i wouldnt scrape. i had it tig welded but the welds dont look so pretty so please dont criticize them
here are the after pics....
this is to show the clearance in the front
and from the side
Modified by JCushing at 2:41 PM 3/8/2004
. here are the after pics....
and from the side
lol, i installed it.... if your talking about the appearance of it well the "coating" that was on there is flaking off
Yet another dissappointment from 10-94. I swear, I haven't seen one header produced by them that was visually pleasing to me. I am sure it probably performs, but basing opinions on appearance of headers, 10-94 would not get my vote. Was this the same header that had the horrible welds and misshaped ports? Also, how come NONE of the 10-94 headers I have seen look anything like the one that they advertised on their website. Its supposed to be equal length coming off the head, and all 4 runners go side bye side under the oil pan for good ground clearance...the ones I have seen are the exact opposite.
not to TJ- but mine should be here next week (I hope) and I'll put some pics up for you to see... maybe I can convice you otherwise
I'm not sure how he could make a tig weld look like that unless he was using the wrong gas. He needs to talk with his welding supply shop and make sure he's using the right gas and rods for the material being welded.
Also, you guys did away with your flex joint, a weld joint(s) will fail sooner than later.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP »</TD></TR><TR><TD CLASS="quote">I'm not sure how he could make a tig weld look like that unless he was using the wrong gas. He needs to talk with his welding supply shop and make sure he's using the right gas and rods for the material being welded.
Also, you guys did away with your flex joint, a weld joint(s) will fail sooner than later.</TD></TR></TABLE>
you talking about the welds around the cat/ o2 bung?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kitkatR »</TD></TR><TR><TD CLASS="quote">it looks loud</TD></TR></TABLE>
lol im not sure what this is supposed to mean but hey thanks i guess
.</TD></TR></TABLE>
i have no idea what gas was being used... the rods were correct though.
.</TD></TR></TABLE>
i cant tell ya if the welds are gonna hold up, only time will tell. the welds did penetrate and they are thick. again these welds were done for me locally.
and yes i feel more power
Im so suprise to hear you gain power with big tube step header on a LS motor... Even a ported LS head does not flow as well as a good v-tec head.... I wonder if you would of gain the same power with a shelf header...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano »</TD></TR><TR><TD CLASS="quote">Someone kill me.</TD></TR></TABLE>
I take it you are not happy with your header?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES »</TD></TR><TR><TD CLASS="quote">
I'M TICKLED PINK!!!!
</TD></TR></TABLE>I'M TICKLED PINK!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DTRFAB »</TD></TR><TR><TD CLASS="quote">Im so suprise to hear you gain power with big tube step header on a LS motor... Even a ported LS head does not flow as well as a good v-tec head.... I wonder if you would of gain the same power with a shelf header... </TD></TR></TABLE>
I think it's a B20 Danny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">
I think it's a B20 Danny.</TD></TR></TABLE>
IC
IC
b20 head = same as LS head, correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris@allmotor.net »</TD></TR><TR><TD CLASS="quote">
b20 head = same as LS head, correct?</TD></TR></TABLE>
I understand the head is the same.....I thought he was running a b20 shortblock...
