Axle nut size?
Old Mar 8, 2004 | 09:18 AM
White Smoke's Avatar
i my honda
Global Mod
Default Axle nut size???
Axle nut size 36mm = JDM 98+ ITR
Modified by si2die4 at 12:59 AM 3/11/2004
Old Mar 8, 2004 | 09:19 AM
JeffS's Avatar
Default Re: Axel nut size??? HELP ASAP (si2die4)
» Search Results
Your search for axle nut returned 52 results.
Old Mar 8, 2004 | 09:33 AM
.RJ's Avatar
.RJ
Well when you have a poor attitude you're not going to get a whole lot of help.
Old Mar 8, 2004 | 09:36 AM
ZygSpeed's Avatar
Default Re: Axel nut size??? HELP ASAP (.RJ)
If it's not the stock USDM ITR 32mm, then its the JDM 36 mm version.
I'm pretty sure the axle nuts from a newer Prelude will fit.
Old Mar 8, 2004 | 09:44 AM
TypeR 599's Avatar
It's 32mm
Old Mar 8, 2004 | 09:54 AM
sackdz's Avatar
Well, at least Jeff's post taught you the correct spelling of 'axle'. Maybe you should thank him instead of getting your panties in a bunch.
Old Mar 8, 2004 | 09:55 AM
Mugen Mike's Avatar
Default Re: Axel nut size??? HELP ASAP (sackdz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">
Well, at least Jeff's post taught you the correct spelling of 'axle'. Maybe you should thank him instead of getting your panties in a bunch.</TD></TR></TABLE>
It's not our fault you have poor spelling
Old Mar 8, 2004 | 09:57 AM
mikestypeR
Guest
Posts: n/a
Default Re: Axel nut size??? HELP ASAP (TypeR 599)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 599 &raquo;</TD></TR><TR><TD CLASS="quote">It's 32mm</TD></TR></TABLE>
I thought it was a 36 mm?
Old Mar 8, 2004 | 09:58 AM
mikestypeR
Guest
Posts: n/a
Default Re: Axel nut size??? HELP ASAP (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">If it's not the stock USDM ITR 32mm, then its the JDM 36 mm version.
I'm pretty sure the axle nuts from a newer Prelude will fit.</TD></TR></TABLE>
ahhhhhhh cleared up I actually read something
Old Mar 8, 2004 | 10:13 AM
JeffS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si2die4 &raquo;</TD></TR><TR><TD CLASS="quote">If some of you ******** would help some one out instead of me typeing already searched every damm time I post we wouldent have a problem now would we! </TD></TR></TABLE>
I vote that people learn to help themselves first.
On the bright side... you learned how to spell axle, you learned what size your nuts are, and I got to prove yet again that I'm an *******...
Old Mar 8, 2004 | 11:14 AM
.RJ's Avatar
.RJ
Default Re: Axel nut size??? HELP ASAP (JeffS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffS &raquo;</TD></TR><TR><TD CLASS="quote">I got to prove yet again that I'm an *******... </TD></TR></TABLE>
w00t!
Old Mar 9, 2004 | 01:47 PM
jiahanhao's Avatar
rtfm? on a honda board?
Old Mar 9, 2004 | 08:43 PM
uNF$@#!'s Avatar
Thank you verry much that is what I was looking for. 36mm it is
Thanks Again
Oh Yah .RJ
I Am tired of hearing the same old **** over and over again on this web board.
I did not have an attitude when I asked the question nor did I wish to take one. Just bcause people think Im a noob, that makes them gods and they think that they can walk all over me and I am just not going to let that happen
Modified by si2die4 at 5:42 PM 3/9/2004</TD></TR></TABLE>
if your tired of hearing it, how about actually searching for the obvious answer?
its like me posting up a thread asking for the paint code for championship white, then crying about it when someone tells me to search
now if you plain just suck at the internet, put up a disclaimer and im sure the nice h-t members will tell you the answer right away
cueto
Apr 20, 2009 08:25 AM
hastingsr
Jun 1, 2008 08:50 PM
MN_BB4_Si
Feb 26, 2007 05:04 PM
SouthernComfort
Oct 16, 2006 04:01 PM
