Prelude mileage
Old Oct 17, 2001 | 10:13 AM
pr0digy1's Avatar
New User
Default Prelude mileage
on my prelude i ususally do only about 320km on a full tank. I've done close to 400km once but only once. I use 91octane or higher. Is this the expected prelude mileage? It seems too low to me.
pr0digy1
Old Oct 17, 2001 | 11:04 AM
HondaDriver4Life's Avatar
Default Re: Prelude mileage (pr0digy1)
what year and model do you have and do you drive hard???
i have a '97 base model (auto) and i get get about 26 miles/gallon doing a combination of city and highway driving. i rarely go into VTEC or accelerate hard. i usually fill up around 300 miles (483 km).
[Modified by HondaDriver4Life, 12:04 PM 10/17/2001]
Old Oct 17, 2001 | 11:09 AM
pr0digy1's Avatar
New User
Default Re: Prelude mileage (HondaDriver4Life)
i have 01 prelude se
i do rev it at least few times a day, and i hit the vtect a few times a day too. Is that why i only get around 320km?
Old Oct 17, 2001 | 11:10 AM
JG Luder's Avatar
I get between 12-16mph. If I race it's lower.
Old Oct 17, 2001 | 11:13 AM
pr0digy1's Avatar
New User
Default Re: Prelude mileage (JG Luder)
how many miles per galon do i get then?
how big is the lude tank?
i do around 320km on a tank, so i guess that's about 200miles
Old Oct 17, 2001 | 11:31 AM
Apocalypse's Avatar
going into vtec a couple times a day certainly kills you. in daily driving i rarely go above 5k rpm. at about 330 miles is where my gas light turns on.
the prelude tank is 15.9 US gallons....
to calculate your mpg or kmpg:
1. fill-up your gas tank
2. reset your odometer
3. drive as you normally do and record the mileage the next time you fill-up
4. note the amount of gas you pump in
5. take the mileage and divided it by the number of gallons you pumped
Old Oct 17, 2001 | 12:50 PM
976's Avatar
976
New User
Reset your ecu, it ups your gas mileage.
Put tire psi to 32, lower or higher decreases gas mileage.
Old Oct 17, 2001 | 01:58 PM
pr0digy1's Avatar
New User
Default Re: Prelude mileage (B21A)
how do i reset my ecu?
Old Oct 17, 2001 | 02:12 PM
Import RP's Avatar
I get like 25 mpg. Like 20 if I drive hard and VTEC a lot. And maybe 26 or 27 if I drive like a grandma. What is the fuel tank capacity of the 4th gen vtec? once the light goes on i usually put in about 13.8 gallons. and can usually go about 330 miles on that much before re-filling.
Old Oct 17, 2001 | 06:55 PM
cecknight's Avatar
Default Re: Prelude mileage (Pyrochaos38)
yeah how do you reset your ECU and is it good to do on an engine with 133k on it.
Old Oct 19, 2001 | 10:50 AM
x97tmp's Avatar
New User
Default Re: Prelude mileage (cecknight)
Hey guys,
I'm new here... I drive a 2001 se I've had it for five months and I've got an aem cai in so far. She's about to go away for the winter.
As for your question, I usually get just over 400km per tank, and the tank is 50 liters.
On the highway I can get up to about 550, but it really depends on how I drive. Can get as low as 350. I think that the way you drive during your break in period might make significant difference.
later
Old Oct 19, 2001 | 03:04 PM
safe driver's Avatar
Default Re: Prelude mileage (x97tmp)
i got about 400 miles on a full tank going to chicago from minneapolis once. i was a little bit surpised because i was cruise at an average of 80 mph.
Old Oct 19, 2001 | 11:48 PM
Import RP's Avatar
Default Re: Prelude mileage (safe driver)
how big is the tank on the 4th gen???
Old Oct 20, 2001 | 04:04 AM
tec-9-7's Avatar
I was occasionally able to hit 400 miles per tank on road trips in my lude too, but 310-325 to the low fuel light was typical in my day-to-day commute.
Old Oct 20, 2001 | 09:06 AM
Honda318dx's Avatar
15.9 gallons.. When my fuel light cuts on, and I got to fill it up, it usually takes about 12.5-13 gallons... so, when your light cuts on, you got about 3 miles to spare, and at the worst, at 20 mpg, it will take you 60 miles
Old Oct 20, 2001 | 09:58 AM
Import RP's Avatar
Default Re: Prelude mileage (Honda318dx)
So if you just ignore your fuel light, 400 miles on a tank should be easy...
Old Oct 20, 2001 | 11:24 AM
Mike95lude's Avatar
Yeah I think I've done that before....I've driven REALLY far after the light goes on multiple times...once time I could NOT find a gas station and I was pushing my luck so much, I was really nervous
Old Oct 23, 2001 | 12:32 AM
BryanS's Avatar
New User
Default Re: Prelude mileage (WadZii)
In answer to the question about resetting the ecu, all you need to do is disconnect your neg battery cable for a few minutes and reconnect it.
CO671
Mar 17, 2014 06:05 AM
AmplifiedGSR
May 25, 2006 09:47 PM
deobiet
Apr 29, 2006 10:36 AM
J_J
Aug 11, 2005 04:49 AM
kitboi826
Mar 27, 2005 07:16 AM
