Spring Rates on a CRX for road racing
What spring rates are you guys using on a crx for circuit driving.
Front and back ?
I need to buy a setup just seeing what best to use.
its a CRX with an R.
Thanx
Front and back ?
Thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motore »</TD></TR><TR><TD CLASS="quote">What spring rates are you guys using on a crx for circuit driving.
Front and back ?
Thanx</TD></TR></TABLE>
go with 12,000lb fronts and 450lb rears.
ibl
Front and back ?
ibl
its a CRX with an R.</TD></TR></TABLE>
?que?
?que?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travis »</TD></TR><TR><TD CLASS="quote">
?que?</TD></TR></TABLE>
You know, CRX with an R, as opposed to CRX without an R, which would be a CX, which would be a Civic but not a CRX.
Sorry, couldnt resist.
As for the original question:
http://www.norcalcrx.org/tyson/coilover.html#04
Modified by thumpu77 at 11:48 PM 3/7/2004
You are telling us that you have a swap. So, that will alter the rates somewhat based on the weight of the engine versus a CRX with the 1.6 D16a6 Si motor. If you have the eqiuvalent of the stock one and are new to SCCA or NASA road racing consider either Skunk 2 or Ground Control sleeves and 500 front/400 rear. We use Koni "yellow" shocks with a variation of these spring rates and the car is fine with the stock motor. I must note that if you plan to street drive the car-it will be stiff compared to the stock rates and shocks.
I noticed in you pictures the mention of a 5 lug conversion. This setup will not be legal for SCCA Improved Touring. What happens with autocross is another matter. Also, you mention a supercharger-for sanctioned roadracing there are no classes that I know of that permit this as an ADD-ON device. This is just a heads up. If you plan to do HPDE events-that is an entirely different deal.
Modified by jc836 at 7:15 AM 3/8/2004
https://honda-tech.com/zerosearch - please search - "spring, springs, spring rates, suspension, etc"
darkjedi022
Suspension & Brakes
20
Sep 19, 2005 06:10 PM
