pluging tire hole
Old Mar 7, 2004 | 08:17 PM
oMek's Avatar
Default pluging tire hole
well today i got a flat on my 3 month old tires. i took it off and the only thing i noticed was a 1 hole the size of a nail. i used the plug thing you get at 7-11. it now holds the air for longer but it still leaks it out slowly. i dont have the $ for a new tire right now.
should i pull the plug out and give it another try?
Old Mar 7, 2004 | 08:20 PM
Echo7847's Avatar
Default Re: pluging tire hole (oMekoneDC2)
Could try another plug, or take it to a tire shop and have them patch it and not have to worry about it.
Echo - who's had 2 tires patched due to two 3" long nails
Old Mar 7, 2004 | 08:22 PM
xplanetearth420x's Avatar
Default Re: pluging tire hole (Echo7847)
take it to the shop they will do it for like 10 dollars,but if its on the wall of the tire it cant be fixed
Old Mar 7, 2004 | 08:25 PM
cougar10ag's Avatar
if it's on the sidewall u need a new tire. i'm assuming it's on the tread since oyu plugged it. but IMHO plugs are temporary so you can get to a gas station. only realy way to repair a hole is to patch it.
Old Mar 7, 2004 | 08:27 PM
oMek's Avatar
Default Re: (cougar10ag)
ok thanks guys, looks like im gona get it patched tomaorw, hopefully its not more than 10$
Old Mar 7, 2004 | 08:43 PM
..::91TEG-G2::..'s Avatar
Default Re: (oMekoneDC2)
one time i took my car in to discount tire, when it didnt have a account or history at a discount tire, and they fixed it for free..
dont know if i was just lucky or what.. but its worth a shot if ur by one
Old Mar 7, 2004 | 09:26 PM
Vinny Chase's Avatar
Default Re: (..::91TEG-G2::..)
If you bought the tires from Discount Tire, it is free.
BTW, those gas station plugs aren't the best idea, I know if you put one in, then by chance get another hole in the same tire and decide to take it to a shop such as Discount Tire, they will not fix it, because the gas station patches, while plugging the leak, also harm the tire.
Old Mar 7, 2004 | 10:14 PM
oMek's Avatar
Default Re: (Vince10984)
so they might not wana patch it because i used a plug?
Old Mar 7, 2004 | 10:17 PM
The-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekoneDC2 &raquo;</TD></TR><TR><TD CLASS="quote"> i used the plug thing you get at 7-11. it now holds the air for longer but it still leaks it out slowly.
The point of the plug is NOT to fix a flat tire but to get you moving again to take your lucky *** to a tire shop and pay $10 to have it patched right!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekoneDC2 &raquo;</TD></TR><TR><TD CLASS="quote"> should i pull the plug out and give it another try?</TD></TR></TABLE>
once being stubborn dumbass myself I can tell you exactly what will happen, yup you can pull out that plug and shove in another one and in 2-4 weeks the leak rate will increase to such a point you'll need to change the plug again. one day that hole will get sooo loose from all the plug sex you've been giving it and it will fall out on the road giving you a pretty fast leaking flat. (I got this on the freeway until the tire got chewed up and ate itself). What can prolong the super plug from 7-11, put the plug in and then a can of the Fix-A-Flat. This will make the slow leak stop and last evening longer. But from there you better be taking real easy trips on it because if you got 2 completely seperate and different products fixing 1 tiny hole on a cheap tire... its probably not a good idea to do "spirited driving"
Old Mar 7, 2004 | 10:34 PM
oMek's Avatar
Default Re: pluging tire hole (Black-LS)
ya, im just glad i didnt have to leave my car there and go get a spare. im gona take it in for a patch tomaorw and hopefully they can still do it.
J_Marc
Mar 27, 2009 09:08 AM
MrXclusivE
Sep 29, 2008 11:40 AM
bob barker
Honda Motorcycles
27
Apr 7, 2004 06:41 PM
4doorH22
25
Aug 17, 2003 11:14 PM
markpaco
12
May 29, 2003 03:52 PM
