Should I "port match" my intake tube?
Old Oct 17, 2001 | 07:32 AM
HX_Guy's Avatar
Default Should I "port match" my intake tube?
I have a DC 3" intake...but it reduces down to 2 3/8 (60mm) where it connects to the throttle body.
My throttle body is 64mm and my intake manifold is 64mm...so it would only make sense to enlarge the intake to that size right?
Old Oct 17, 2001 | 07:41 AM
FAST94GSR's Avatar
New User
Default Re: Should I "port match" my intake tube? (HX_Guy)
Definitely you want to make the transition as smooth as possible. You don't want air turbulence.
Old Oct 17, 2001 | 07:43 AM
Nick M's Avatar
Default Re: Should I "port match" my intake tube? (FAST94GSR)
Well yes and no, good turbulence is what makes flow occur, if there is no turbulence at all then the air isnt moving, but i understand what u meant. When an engineer says "The flow is turbulent" thats a good thing. Thermodynamics 101
Old Oct 17, 2001 | 07:45 AM
HX_Guy's Avatar
Default Re: Should I "port match" my intake tube? (Hondasport94)
...so do it or not?
Old Oct 17, 2001 | 07:46 AM
D's Avatar
D
eeeert...
pressure drop is what makes flow occur.
make it smooth.... it will become turbulent (good for mixing and burning fuel) on its approach through the plenum/combustion chamber.
D
Old Oct 17, 2001 | 08:51 AM
HX_Guy's Avatar
Default Re: Should I "port match" my intake tube? (D)
Someone said the reduction from 3" to 2 3/8" helps speed up the air and I should leave it as is...is that true?
Ive heard about this theory before..which is what the Iceman intakes do...but those intake gradually decrease in size.
The DC tube abruptly reduces from 3" to 2 3/8" in about the last 2" of piping.
Thoughts?
Old Oct 17, 2001 | 09:03 AM
Willard's Avatar
pV=nRT... moles... laminar flow.... bahhhh
Either have the reduction in the intake... or at the throttle body. The choice is yours. Enlarge it to promote laminar flow.
Shouldn't have to worry about it too much... without VTEC you may not notice the difference anyway....
Willis
Old Oct 17, 2001 | 09:46 AM
HX_Guy's Avatar
Default Re: Should I "port match" my intake tube? (Willard)
OUCH! Low blow!
Dyno session coming Saturday...maybe Ill break 175 WHP?
[Modified by HX_Guy, 10:46 AM 10/17/2001]
casserlyshane
Oct 6, 2014 04:11 PM
SLiCkNiCk
Honda Civic (2006 - 2015)
Nov 8, 2006 10:53 AM
pbink
Oct 18, 2005 05:18 AM
whatVTEC
Sep 19, 2003 10:42 PM
HX_Guy
Oct 17, 2001 07:25 AM
