Potenza S03 or Toyo RA1?
Old Oct 17, 2001 | 07:18 AM
Petah's Avatar
Default Potenza S03 or Toyo RA1?
I was looking at these tires and they both seems to be priced very closely......Which one of these would make a better track tire?
Old Oct 17, 2001 | 07:24 AM
The Professional's Avatar
New User
Default Re: Potenza S03 or Toyo RA1? (eg-six)
Yokohama A032R, Kumhos, or Hoosiers. Why bother with S-03 and RA1?
Old Oct 17, 2001 | 08:34 AM
DB2-R81's Avatar
25 Year Member
Default Toyo RA1
The Toyo RA-1 makes an excellent long warring track tire. Unless you have a lot of wet weather they are at their best when shaved or after a few sessions to reduce tread depth.
Old Oct 17, 2001 | 09:44 AM
Big Phat R's Avatar
I've used both the RA-1 and the A032R at the track and I like the RA-1 better. Mind you the treadwear rating on the Toyos is only 40 - so they are going to wear out faster than the Yoko's. Sidewall stiffness is about the same for both.
My observations of the Toyo's is that they are initially "greasy" when they have a lot of tread and progressively get better and better until they cord. Many of the racers who use RA-1s use "shaved" versions which act very much like slicks. For occasional track use, the RA-1 is a much more economical choice than Hoosiers. They also have much more progressive break-away than Hoosiers - and more audible feedback for beginners. I would stay away from Hoosiers if you are a beginner/novice - you're not getting your money's worth out of the tires.
Potenza S03s are a great street/track tire - but they would probably chunk if you used them at a track with a rough road surface - but you will have better grip using ANY R compound tire.
thenick
Oct 1, 2005 07:29 PM
Black R
Apr 29, 2003 07:18 PM
Solipsist
30
Apr 17, 2003 09:06 AM
YodaIsGod
Jan 2, 2002 05:38 PM
ActiveAero
Oct 29, 2001 04:31 AM
