Engine Mount Do you need this one? . .
Old Mar 7, 2004 | 05:42 PM
blackboosted2's Avatar
Default Engine Mount Do you need this one? . .
Just completed a b series swap into my EG hatch, and the mount near the A/C compressor was broken. I left it out as a temp. fix and was told by some I dont even need it. The engine doesnt seem anything out of the ordinary without it. Can I leave it without? Or should I be picking up another mount before any powershifts/hard launches take place?
I have all the other mounts, both side mounts, passenger tranny mount, and rear mount. The driverside front lower mount is the only in question.
I have searched, and find mixed results!
Old Mar 7, 2004 | 05:49 PM
dthrone's Avatar
Default Re: Engine Mount Do you need this one? . . (blackboosted2)
I dont have it in mine.....But you should get the mount inserts for the Drivers and Passengers side motor mounts.
And the Rear sorry
Old Mar 7, 2004 | 05:53 PM
60-1teg's Avatar
yes you need to pick one up if not you will tear other mounts up.
Old Mar 7, 2004 | 05:58 PM
diearzte2
Guest
Posts: n/a
Default Re: Engine Mount Do you need this one? . . (2.0lhatch)
Your intake kicks ***.
Old Mar 7, 2004 | 06:03 PM
dthrone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.0lhatch &raquo;</TD></TR><TR><TD CLASS="quote">yes you need to pick one up if not you will tear other mounts up. </TD></TR></TABLE>
Not if you buy mount inserts!
Old Mar 7, 2004 | 08:21 PM
DMF's Avatar
DMF
Default Re: Engine Mount Do you need this one? . . (ANOTHER_JDM_EG6)
I don't run that mount, but I have Hasport race mounts. If you run something like that or inserts you don't need it, but with stock mounts I would still run it.
Old Mar 7, 2004 | 08:34 PM
dthrone's Avatar
Default Re: Engine Mount Do you need this one? . . (DMF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DMF &raquo;</TD></TR><TR><TD CLASS="quote">I don't run that mount, but I have Hasport race mounts. If you run something like that or inserts you don't need it, but with stock mounts I would still run it.</TD></TR></TABLE>
I like this guy!
Old Mar 7, 2004 | 09:07 PM
Default Re: Engine Mount Do you need this one? . . (diearzte2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diearzte2 &raquo;</TD></TR><TR><TD CLASS="quote">Your intake kicks ***.</TD></TR></TABLE>
ha, it was free.
My d16 AEM CAI wouldnt fit without a lot of cutting
Old Mar 7, 2004 | 09:10 PM
Mr HYDE's Avatar
i dotn run it but i filled my mounts with window **** so
Old Mar 7, 2004 | 09:11 PM
Who Said's Avatar
im running mine with the 2 vibration mount (trans side and engine side) with the inserts also have the insert for the rear trans.makes the dash rattle like crazzy but gets the power to the ground without all the wheel hope
saemoonyang
11
Nov 3, 2011 12:33 PM
Razr2
18
Mar 15, 2008 08:59 PM
typeR#0427
May 15, 2005 09:23 AM
Loveless
Oct 14, 2003 09:52 AM
crxY-49
12
May 8, 2003 11:04 PM
