would a b18b auto trans fit in a 93 integra automatic?
Old Mar 7, 2004 | 05:34 PM
rhdjdmda6's Avatar
Default would a b18b auto trans fit in a 93 integra automatic?
would the mounts be different? can u guys help me, i need to know asap. thanks
Old Mar 8, 2004 | 07:46 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: would a b18b auto trans fit in a 93 integra automatic? (rhdjdmda6)
the b18b is hydraulic. yours is a cable tranny. you would have to convert your car to be able to accept a hydro setup.
Old Mar 8, 2004 | 06:27 PM
rhdjdmda6's Avatar
Default Re: would a b18b auto trans fit in a 93 integra automatic? (vtecb20coupe)
i thought only the manual trannys were different, its a auto tranny. shouldnt it be all the same
Old Mar 8, 2004 | 10:12 PM
CoryTurner's Avatar
hey,
vtecb20coupe is thinking of a mnaual tranny. no they won't work exactly. the casing physically on the outside looks teh same, the sensor connectors should be differant and the splines on the differential may not fit on the other gen's axles. but i'm not sure on that last one.
Old Mar 9, 2004 | 04:03 PM
rhdjdmda6's Avatar
Default Re: (CoryTurner)
so if i buy new axles, do you think it'll fit then? thanks
Old Mar 11, 2004 | 09:28 AM
CoryTurner's Avatar
hey,
i'm not exactly sure. you should just call up your local performance shop.
Old Mar 11, 2004 | 01:17 PM
nos51's Avatar
they will mate up but the b18b trans uses different shift solenoids,so it wont work electricly
Hatchback_Pat
Oct 14, 2012 08:52 PM
94 Integra
Apr 7, 2008 11:40 AM
94 Integra
Mar 30, 2008 10:16 AM
