Directions to have OEM Fogs on with High beams?
Old Mar 7, 2004 | 04:49 PM
95TEG's Avatar
Default Directions to have OEM Fogs on with High beams?
Does anyone have instructions on how to do this for a 98+ Integra? I want the fogs to stay on with the high beams.
Old Mar 7, 2004 | 06:23 PM
95TEG's Avatar
Default Re: Directions to have OEM Fogs on with High beams? (95TEG)
ttt
Old Mar 7, 2004 | 07:40 PM
JBBNJ609's Avatar
wire it to a switch. . . or does use the stock wiring harness.. . .
its not legal for more then 4 lights on at once , thats why honda did that btw
Old Mar 7, 2004 | 07:42 PM
TEXN3's Avatar
i've wondered this after seeing the hid hi/low-beam retrofit.
but...
the aiming of the hi-beam is too high for a fog usage. fog lights tend to be aimed lower, not out so far.
now, if you can aim the hi-beam low with out affecting the low-beam aim, then you're ok.
just run a new switch to the lights and a lower-rating bulb. you should be ok. also, if it is a yellow-tinted lense or bulb, then you wouldn't be given crap from law enforcement. a driving light can be a white color.
good luck man.
Old Mar 7, 2004 | 07:56 PM
99IntegraGS's Avatar
Default Re: Directions to have OEM Fogs on with High beams? (jason bouchard)
In Florida I don't think it's legal to have auxillary lighting on with the highbeams. I got pulled years ago for having highs and driving lights going at the same time. The cop told me it was supposed to be wired so that when the highbeams are switched on, the driving lights switch off.
Old Mar 7, 2004 | 08:07 PM
95TEG's Avatar
Default Re: Directions to have OEM Fogs on with High beams? (99IntegraGS)
Lets just say its for "off road purposes only"
Old Mar 7, 2004 | 08:11 PM
TEXN3's Avatar
factory fogs will cancel when the hi-beams are switched on.
Old Mar 7, 2004 | 09:05 PM
cougar10ag's Avatar
if you have the need to turn your highs on, then theres no need for fogs... ie, in FOG!
same with driving lights.
hun8504
Lighting
Jan 7, 2013 05:27 PM
MILANO_RED_CL9
Acura TSX
Dec 8, 2010 05:01 AM
redline870
45
Oct 12, 2008 01:23 PM
Dougie Pants
Honda Fit
17
May 5, 2007 04:07 PM
