91 accord fuel pump
Old Mar 7, 2004 | 10:14 AM
91according's Avatar
Default 91 accord fuel pump
i think i need a nwew fuel pump i will drive my car for like 2 day and then it will die and wont sart for like 5 minutes and it does this until it sits for like 5 hours then it is fine again what could this be just changed plugs, plug wires, cap and rotor and fuel filter what else could it be
Old Mar 7, 2004 | 11:16 AM
Default Re: 91 accord fuel pump (91according)
help
Old Mar 7, 2004 | 05:24 PM
AngryTroll's Avatar
Do a search on 'main relay'.
If your relay is okay, check to see if you are losing spark (when it won't start).
If you're losing spark, your igniter is probably on its way out.
These aren't the only possibilities, just the most common.
Old Mar 7, 2004 | 05:52 PM
fizzbob7's Avatar
Default Re: 91 accord fuel pump (AngryTroll)
bad relays are REALLY common, but usually only in really warm weather......to add to what has already been said, you can always listen to check if the pump is coming on when the key is in the on position.....or pull a line and see if it's pumping gas......
Old Mar 7, 2004 | 09:10 PM
John Gordon's Avatar
Also, when was the last time you changed your fuel filter? If its clogged, it will ast like a bad fuel pump.
I agree with the last poster. Go through the basics. Air, fuel, spark.
Old Mar 8, 2004 | 08:02 PM
Default Re: 91 accord fuel pump (John Gordon)
did you not read my post i just put a new fuel filter on it
tribalpnoy
Dec 11, 2009 08:04 PM
jstafase
Jun 15, 2009 09:15 PM
axionm1k
Jun 4, 2008 09:09 AM
zcmotor
30
Mar 17, 2008 05:53 PM
Hayasa15
Mar 25, 2003 12:15 PM
