Broke off a a nut/part of bolt holding fuel rail down, please help!
What can I do now? I was tightening the last nut (one of three) that actually holds the fuel rail down and it broke clean off.... What can I do now? I looked at my dealership service manual and it looks like it might be possible to just replace the stud, but it would be real hard... Do I have to replace the entire intake manifold, or do you think that if I take the intake manifold off I wil be able to replace the stud? Thanks for your help, as I am really pissed off at myself for doing this and want my baby back now
i take it you got your injectors. you can replace the stud. it is easy to do. you just need a stud extractor or a pair of vice grips. when installing the stud all you need is to tighten it snug.
Yea, thanks a bunch, they came REAL quick
. That makes my day knowing that it is replaceable. So I assume I can extract the stud while everything is still intact.
BTW do I really need both the plastic and rubber gaskets?
Thanks a nuch for your help, and the injectors- I can vouch for you anytime
. That makes my day knowing that it is replaceable. So I assume I can extract the stud while everything is still intact. BTW do I really need both the plastic and rubber gaskets?
yes the plastic pieces are shims for the prelude manifold only. definatly need them. be sure to pull the old ones out first though.
Quik Chris
Sep 27, 2002 09:04 PM
