Euro r Intake manifold Question?????
Old Mar 6, 2004 | 09:36 PM
jdmh22ek9's Avatar
Default Euro r Intake manifold Question?????
I just finished my 2001 Euro Accord R motor and went to start it up and there is no throttle screw so my idle is all messed up i have tried a couple and different ones and non work has anyone ever had to replace this what one works?
ls:does not fit
gsr: no luck
F22: no go either
Can anyone help???
Old Mar 7, 2004 | 12:19 AM
aeolus's Avatar
Default Re: Euro r Intake manifold Question????? (jdmh22ek9)
are you talkin about the idle control valve??because those motors used a different kind of valve.i dont think it will ever work unless you get a adapter plate to use the prelude,ls,or civic one,and get another tb.
Old Mar 7, 2004 | 12:51 AM
jdmh22ek9's Avatar
it is the little screw on the top of the throttle body. It almost looks like it doesnt have any threads in there
Old Mar 7, 2004 | 06:22 AM
junbb1's Avatar
Default Re: (jdmh22ek9)
he understands that you need an idle adjust screw. but what aelous is saying is that the iac valve has a different plug than the one on your harness. an itr throttlebody is supposed to bolt right up from what i have heard. i used the stock 94 h22a t-body. i had to modify it though. read: https://honda-tech.com/zerothread?id=740328
Old Mar 7, 2004 | 07:31 AM
irev210's Avatar
itr throttle body works just fine.
If you are too cheap to buy one, u can do what we did and **** with the set screw to keep the throttle body always open then readjust your TPS sensor as a short term solution untill a ITR throttle body was located.
They are the exact same thing, just one has an idle screw
my question is how did u set up your aicv?
Old Mar 13, 2004 | 03:47 PM
Peter K's Avatar
New User
Default Re: Euro r Intake manifold Question????? (irev210)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 &raquo;</TD></TR><TR><TD CLASS="quote">
my question is how did u set up your aicv?</TD></TR></TABLE>
opps nm
Modified by Peter K at 12:04 PM 3/14/2004
Old Mar 13, 2004 | 04:27 PM
99spanishGT
Guest
Posts: n/a
Default Re: Euro r Intake manifold Question????? (Peter K)
just get one of the wire twist for electrician use. and stick it in there!! thats what i use and it works great!!
Old Mar 13, 2004 | 05:16 PM
k_spek's Avatar
Default Re: Euro r Intake manifold Question????? (spanishlude)
Wait so it is possible to use the Euro R iacv? How do you rewire it or whatever?
Old Mar 13, 2004 | 10:30 PM
Eddiebx's Avatar
u cant use the euro-r iacv with the stock ecu cuz it cant drive a 3wire type iacv. if you have maybe an AEM EMS, u can set it up to wrok with the 3 wire.
Old Mar 13, 2004 | 11:01 PM
AkEuro_R's Avatar
Default Re: (Eddiebx)
I wouldnt skimp on money in this project, buy a throttle body, whether it be an ITR or Erick's Racing or something. Get an IACV that is 2-wire and be done. I bought the install kit from SE93 to make relocating the iacv a breeze. The vacuum on my motor was so harsh with the 3 wire iacv that it was sucking my top radiator hose closed.
ejvtec
Jan 24, 2010 02:27 PM
Gho$t
Nov 10, 2009 10:26 PM
texaszcrx
Mar 24, 2009 05:56 AM
IDVirii
Mar 10, 2008 10:58 AM
dplatt
Jul 14, 2002 09:00 AM
