what happens if i start my crx with brake booster hose disconnected?
Old Mar 6, 2004 | 06:22 PM
djnikko's Avatar
Default what happens if i start my crx with brake booster hose disconnected?
exactly as the title says.....
anyone?
Old Mar 6, 2004 | 06:26 PM
X2BOARD's Avatar
Default Re: what happens if i start my crx with brake booster hose disconnected? (djnikko)
Well, for one thing... you're brakes will be very hard to press.
Old Mar 6, 2004 | 06:36 PM
djnikko's Avatar
Default Re: what happens if i start my crx with brake booster hose disconnected? (X2BOARD)
im only wanting to idle the car, not wanting to go anywhere. lol
Old Mar 6, 2004 | 07:01 PM
virginia_dude's Avatar
well you will have one ******* large vacume leak. Unless you plug that vacume port. other than that it will run like it does with it hooked up. Albe it will barely functioning brakes.
Old Mar 8, 2004 | 05:10 AM
X2BOARD's Avatar
Default Re: what happens if i start my crx with brake booster hose disconnected? (virginia_dude)
Ahem...aside from VERY HARD to press brakes... the car will idle at like 2.5-3k rpm.
Don't ask how I now know this...lol
Old Mar 8, 2004 | 05:15 AM
I am assuming the person doing this has the common sense to plug the vacume line. Or you end up idling at that high an RPM if it idles at all.
I mean the vacume line on the Intake manifold. You will have a f***ing massive vacume leak if you don't, thats a fairly large vacume port.
Old Mar 8, 2004 | 05:39 AM
X2BOARD's Avatar
As I said... I'm not speculating here...it idles...I tried it to see what would happen...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">Ahem...aside from VERY HARD to press brakes... the car will idle at like 2.5-3k rpm</TD></TR></TABLE>
Old Mar 8, 2004 | 05:54 AM
djnikko's Avatar
thanks guys yeah it did idle a bit high, and still does with the brake booster connected, suggesting possibly i have another vacuum leak. I am working on a log manifold for my vacuum sourcing, instead of what i got at the moment which is rubber hoses superglued to plastic T pieces LOL
DUKE LADUKE
25
May 10, 2011 09:21 AM
paniaguae640
Mar 2, 2008 09:58 AM
category5 SI
May 30, 2007 04:06 PM
swiftstyles
Jan 12, 2004 02:12 PM
AcidGord
Dec 24, 2003 10:38 AM
