Cam Gear Setting?
Old Oct 16, 2001 | 08:50 PM
BeanRacer's Avatar
New User
Default Cam Gear Setting?
At what degree should I set my AEM cam gears with stock ITR cams and valve train?
Old Oct 16, 2001 | 08:53 PM
Jason's Avatar
Default Re: Cam Gear Setting? (BeanRacer)
at 0 until you get onto a dyno to properly tune it....
Old Oct 16, 2001 | 08:54 PM
NAB20C5's Avatar
Take it to a dyno...any get a Fuel pressure reg. while ur at it...and maybe a vtec controller...but all in all get on the rollers...try different settings like adv. the intake a couple of degrees, ret. the exh. cam a couple etc. and if you don't know what you are doing, get some one that does...no need to blow your motor from not reading your gears correctly, Eric
Old Oct 16, 2001 | 09:28 PM
t's Avatar
t
Try advance 2 on the intake cam and retard 1 on the exhaust.
Or
Try 0 on the intake cam and retard 2 on the exhaust.
Or
Try 3 on the intake cam and 0 on the exhaust.
Make sure you air fuel is not to lean or rich while testing.
EGhatch87
Jun 22, 2008 10:25 PM
stevethefishguy
15
Aug 30, 2006 06:53 PM
purpleh22
May 3, 2006 03:38 PM
jdmcx
10
May 7, 2004 04:04 PM
B_1_8_hatch
Mar 17, 2003 05:53 PM
