type of tranny fluid for H22A LSD tranny?
Old Mar 6, 2004 | 01:38 PM
Honda Sport's Avatar
Default type of tranny fluid for H22A LSD tranny?
can I go ahead and used honda MT fluid in a JDM h22a LSD tranny or do I need some type of special fluid? or should I go ahead with penzoil/GM syncromesh?
Old Mar 6, 2004 | 01:57 PM
satan_srv's Avatar
Default Re: type of tranny fluid for H22A LSD tranny? (Honda Sport)
honda MTF is fine.
Old Mar 6, 2004 | 02:51 PM
tylek17's Avatar
gl-5 80w-90
Old Mar 6, 2004 | 02:55 PM
satan_srv's Avatar
Default Re: type of tranny fluid for H22A LSD tranny? (tylek17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tylek17 &raquo;</TD></TR><TR><TD CLASS="quote">gl-5 80w-90</TD></TR></TABLE>
why the hell would you put gear oil in there? It is not a clutch-type LSD!
Old Mar 6, 2004 | 03:50 PM
thanks for the replies. I hear so much about synromesh, so I go ahead and get some? does any auto parts store carry penzoil syncromesh?
Old Mar 6, 2004 | 04:02 PM
georgiajdm's Avatar
Default Re: type of tranny fluid for H22A LSD tranny? (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">
why the hell would you put gear oil in there? It is not a clutch-type LSD!</TD></TR></TABLE>
because he has a 2 way kaaz, which is a clutch type lsd.
Old Mar 6, 2004 | 04:38 PM
Default Re: type of tranny fluid for H22A LSD tranny? (georgiajdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgiajdm &raquo;</TD></TR><TR><TD CLASS="quote">
because he has a 2 way kaaz, which is a clutch type lsd.</TD></TR></TABLE>
JDM h22a LSD tranny's have 2 way kaaz??
Old Mar 6, 2004 | 06:00 PM
georgiajdm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport &raquo;</TD></TR><TR><TD CLASS="quote">
JDM h22a LSD tranny's have 2 way kaaz??</TD></TR></TABLE>
no, why would oem honda use a clutch type lsd????
He just happens to have the kaaz because that's what came in the swap when he got it.
Old Mar 6, 2004 | 06:05 PM
Ataraxia's Avatar
Honda MTF would probably be a good choice.
Old Mar 6, 2004 | 07:14 PM
durs, my bad, not reading carefully. I thought you said the JDM h22a's come with 2 way Kaaz LSD. I was like WTF?? hahaha
Old Mar 6, 2004 | 07:54 PM
satan_srv's Avatar
He posted tranny fluid for an entriely different application, that's retarded How is that going to help anybody? BTW when I had my Kaaz I used the Kaaz fluid
Old Mar 10, 2004 | 09:49 AM
ALLMOTORJ's Avatar
Aren't the JDM 4th gen h22 tranny's clutch type?
Old Mar 10, 2004 | 09:50 AM
Kal's Avatar
Kal
Default Re: type of tranny fluid for H22A LSD tranny? (4gotpasswordAGAIN)
i think they're helical gear type
satan_srv's Avatar
Default Re: type of tranny fluid for H22A LSD tranny? (kxkal)
helical. that's wy you don't need special fluids.
Old Mar 10, 2004 | 10:26 AM
ALLMOTORJ's Avatar
Hmmm... the older (93-95) JDM LSD h22's are Gear type? I thought they were Clutch because I was spinning only one wheel at the race track (Clutch wearing out)
Old Mar 10, 2004 | 10:32 AM
fastludeh22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gotpasswordAGAIN &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm... the older (93-95) JDM LSD h22's are Gear type? I thought they were Clutch because I was spinning only one wheel at the race track (Clutch wearing out)</TD></TR></TABLE>
you running slicks? its still oem, not racing. my jdm lsd spins both, w/bf drags 1st and 2nd(although the back starts to drag in second)
Old Mar 10, 2004 | 10:33 AM
Default Re: (Honda Sport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the replies. I hear so much about synromesh, so I go ahead and get some? does any auto parts store carry penzoil syncromesh?</TD></TR></TABLE>
ya i was thinking the same thing...my 3rd doesnt like speed shifting...and i changed my tranny fluid twice in 10k...honda mtf
Old Mar 11, 2004 | 10:54 AM
C M S's Avatar
Do you guys recomend Synthetic or just stick to Honda OEM? When I had my non-LSD B16 I was using BG synchro shift. The **** was great. But now I have a 94 JDM H22-LSD, should I use synthetic w/ this motor or H-oem? THANKS!!
Old Mar 11, 2004 | 07:04 PM
C M S's Avatar
Default Re: type of tranny fluid for H22A LSD tranny? (1SICJDM)
Bump for a answer...
Old Mar 12, 2004 | 03:39 AM
KENLUDE97's Avatar
Well if the tranny is shifting smoothly, then use Honda MTF, or if it ginds then switch to GM syncromesh. Good luck.
Old Mar 12, 2004 | 05:54 AM
c1civic's Avatar
im runnin syncromesh in mine with a quafie lsd
Old Mar 12, 2004 | 09:06 AM
quickchris's Avatar
I run the synchromesh friction modified in my m2b4 tranny.Works great.
Old Jul 7, 2004 | 11:49 AM
93H22ACX's Avatar
Default Re: (quickchris)
syncromesh and a little motor oil (didnt have enought ) with my quaife lsd.....
honda_mike
Apr 14, 2008 01:49 AM
b18avtec(A!!M0TOR)
Jan 29, 2007 03:22 PM
Vitt1
Feb 6, 2006 07:58 PM
ak
Aug 4, 2005 07:48 PM
JDMcivicSiRII
Jul 28, 2004 12:07 PM
