88-89 honda civic std hb to ls 93 conversion
Old Mar 6, 2004 | 12:55 PM
vtecsk8r's Avatar
Default 88-89 honda civic std hb to ls 93 conversion
i have the std 89 hb.and i am getting a ls longblock for 100 dollars .i would like to know how easy it is to wire the ls to my car.i never have converted a dual port injection to multi port before,although i have heard it is very easy .
Modified by vtecsk8r at 3:00 AM 3/7/2004
Old Mar 6, 2004 | 03:54 PM
Kendall's Avatar
First off, your car should have dual point, not single point injection. The wiring is surprisingly simple. You will have to convert some things (distributor, fuel system) to OBD-0, and you'll have to source the necessary items to install the engine (tranny, mounts, manifolds, etc.). I'm not sure if your stock ECU will run it, but I'd get an ECU from a 90-91 Integra just to be sure. Ask the Hybrid forum, they'll be able to help you better than anyone.
vtecsk8r
Apr 9, 2004 06:40 PM
CRX_GUY_123
Mar 24, 2004 11:33 AM
LSVTECoupe
Sep 29, 2003 04:06 PM
LSVTEC96HB
May 1, 2003 10:02 PM
