Differences between S2000 87mm pistons, and H22a 87mm pistons
Old Mar 6, 2004 | 12:24 PM
LudeHatchH22a's Avatar
Default Differences between S2000 87mm pistons, and H22a 87mm pistons
I'd like to know what the difference is between the pistons?
Is is the wrist pin height??
Because Today has pistons for the s2000 that do not require resleeving, and as far as i know, they use the same FRM as we do in the h22a.
The did this be keeping the same pistons to wall clearences and make it a eliptical shape to compensate for the sideloading im guessing.
Anyone with specs post them up, pics would help too.
Might be a cheap, custom way out of sleeving EVEN THOUGH the pistons,ring, and pin set costs 1700 some.
anyways, let me know
Old Mar 6, 2004 | 01:19 PM
irev210's Avatar
Default Re: Differences between S2000 87mm pistons, and H22a 87mm pistons (LudeHatchH22a)
the wrist pin hight is different
if you were to put them into an h22 block they wouldnt quite come to the top of the block
However, there was some talk about decking the block blah blah blah
in the end i dont think it was said to be a easily doable
HotWheelz
May 4, 2006 09:33 PM
speedyonez
Jun 28, 2005 11:20 PM
MyVtec8yourV8
Aug 29, 2004 10:34 AM
accorracer
May 3, 2003 11:45 AM
