camber kit?
Old Mar 6, 2004 | 12:14 PM
JDMTurboEG6's Avatar
Default camber kit?
would i need to do an alignment before and after i installed my camber kit? i have an ingalls camber kit and just wanted to knwo if i should or not?
Old Mar 6, 2004 | 12:16 PM
MikeNice's Avatar
Default Re: camber kit? (JDMTurboEG6)
I talked to shops and people have told me to do the alignment after you put the camber kit in. Otherwise you will throw off the alignment again. And their machines are more accurate then the human eye.
Old Mar 11, 2004 | 07:35 PM
doublejz's Avatar
Default Re: camber kit? (MikeNice)
if you like your tires, get one after you put the kit on. This way they will also correct your camber to the appropiate specs
Old Mar 11, 2004 | 07:43 PM
quicksol95's Avatar
Default Re: camber kit? (doublejz)
why would you do it better
just save your money and get a good one after you install the kit
Old Mar 11, 2004 | 07:53 PM
SD_EM1's Avatar
get it AFTER you install the camber kit
t.phan
Dec 23, 2007 03:33 PM
wwong510
Feb 13, 2007 11:11 PM
aznchino16
Aug 29, 2003 05:26 AM
