CANT TAKE OFF MY H22A4 OIL PAN!!
Old Mar 6, 2004 | 09:54 AM
tuan...'s Avatar
Default CANT TAKE OFF MY H22A4 OIL PAN!!
well a few weeks ago, i dropped a locknut down the ports on the side of the valves. and it is supposivel in the oil pan now. i took every single bolt/nut on the oil pan and it wont come off!! i tried hittin it witha rubber mallet, prying it on the corner by the crank pulley. but all it does it chip away at my oil pan. stupid *** thing wont budge!! plz help!!!
Old Mar 6, 2004 | 10:01 AM
delslowh23's Avatar
Default Re: CANT TAKE OFF MY H22A4 OIL PAN!! (h22a4_dc2)
you have to be missing one
Old Mar 6, 2004 | 10:33 AM
tuan...'s Avatar
all bolts/nuts are out, i quadruple checked
Old Mar 6, 2004 | 10:57 AM
Aaron.Hillman's Avatar
Default Re: (h22a4_dc2)
pry it softly with flat screw driver all the way around. Probably you need 2 or 3 screwdrivers.
Old Mar 6, 2004 | 01:26 PM
irev210's Avatar
Default Re: (aahill69)
if you have a 5th gen honda uses hondabond instead of a rubber gasket
it REALLY makes it a BITCH to take off
you got to carefully pry
take a screw driver and a hammer and hammer the screwdriver carefully inbetween the pan and the block
Once it starts to come off, then it is easy after that
Have fun spending like a hour with a gasket scraper getting all the old honda bond off
Cheap *** honda...
Old Mar 6, 2004 | 01:32 PM
LudeyKrus's Avatar
Make sure the flywheel cover and everything else is not in the way.
After making sure that EVERYTHING is clear, start prying and pouding until it starts coming loose. There is no easy way about it.
Old Mar 6, 2004 | 02:27 PM
TurboSam's Avatar
Default Re: (irev210)
and be extra careful not to crack it b/c it is made from cast aluminum, which can make it easy to break
Old Mar 6, 2004 | 04:11 PM
irev210's Avatar
Default Re: (Turbo Sam)
a good trick some people do is to use a magnet to attract and drag the nut to the drain hole. Most mechanics wouldnt even bother to take off the pan to get the nut out they would just leave it there
Old Mar 7, 2004 | 06:16 PM
flyrod's Avatar
I was just going to say that! One nice thing about the aluminum pans...
omiehomie
Nov 23, 2009 08:54 PM
omiehomie
Nov 23, 2009 06:06 PM
HyphyBB6
Apr 13, 2009 05:18 PM
92hondalude
Sep 27, 2005 09:26 PM
hondaracing1
11
Mar 18, 2004 04:01 PM
