supporting the motor while dropping tranny?
Old Mar 6, 2004 | 09:22 AM
NoLipRacen's Avatar
Default supporting the motor while dropping tranny?
i should be getting the tranny out today but i need to know how i can support it i dont have an engine hoist nor do i have the money to buy or rent one. i know that i can jack it up but where, and do i need to cushion it or something, like with a piece of wood? thanks guys!
Old Mar 6, 2004 | 09:24 AM
Greyout's Avatar
Default Re: supporting the motor while dropping tranny? (NoLipRacen)
the motor is fine being held in by just the 3 mounts. It will sag about 1-2 inches, but this will actually make it easier to get out.
if you decide to make it easy on yourself and remove the front cross member also, do that first, and then use a floor jack and put it under the front motor mount. Then remove the tranny mount.
If you're concerned about supporting the tranny, you should be able to handle it fine with a friend.
I had someone on the passenger side, underneith the car, lifting it slightly to take the pressure off the input shaft, while I sat on the valve cover and slid the transmission off the motor, while holding it from above.
Old Mar 6, 2004 | 09:29 AM
NoLipRacen's Avatar
Default Re: supporting the motor while dropping tranny? (Greyout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout &raquo;</TD></TR><TR><TD CLASS="quote">if you decide to make it easy on yourself and remove the front cross member also, do that first, and then use a floor jack and put it under the front motor mount.</TD></TR></TABLE>
my helms tells me to remove the center beam, that isnt the crossmember is it? sorry for the dumb ? i had a long night last night and im tired...
racebum
Aug 18, 2008 10:11 AM
jikespingleton
Dec 18, 2006 02:20 PM
91 ZC hatchback
Jan 17, 2006 02:54 AM
Sinner
Jun 13, 2004 10:20 PM
