Will d15 rod bearings fit a d16???
Old Mar 6, 2004 | 08:04 AM
Burke's Avatar
Banned
Default Will d15 rod bearings fit a d16???
None of the stores can get d16 rod bearings, but advance can get d15's for like $27. honda can order the d16's but i'll have to wait a week and dont have the time to do so. Any suggestions on where to get them??
THanks
Burke
Old Mar 6, 2004 | 11:59 AM
Burke's Avatar
Banned
Default Re: Will d15 rod bearings fit a d16??? (Burke)
anybody know???
Old Mar 6, 2004 | 12:11 PM
DonF's Avatar
I would say no, the D-16's are larger bore, but without eng. #'s I am only 95% sure. I guess that is why they have diff. part #'s.
Old Mar 6, 2004 | 12:27 PM
Burke's Avatar
Banned
Default Re: Will d15 rod bearings fit a d16??? (DonF)
engine #'s as in d15b7 and d16z6. ive been searching through helms and cant seem to find rod diam anywhere. i just found it odd that they can get d15 bearings but not d16. oh well.........
Old Mar 6, 2004 | 12:42 PM
S9i1R's Avatar
They might be the same for all d-series 99% sure. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">before you can order bearings for your car, you have to take the motor apart. There is a number on the rod, crank and inside of the block...those numbers tell you what bearings to run...
...Honda has them sorted for blueprinting from the factory</TD></TR></TABLE>
order them from the dealer for that reason. hit up BERT-O he can get them for under $10ea. don't quote me though
Old Mar 6, 2004 | 12:56 PM
Burke's Avatar
Banned
Default Re: Will d15 rod bearings fit a d16??? (S9i1R)
i know the whole color coding. but i took out the rods in haste and dont know which were which. i just want a generic set for the time being. i hit up bert o
thanks
Burke
Old Mar 6, 2004 | 03:24 PM
DonF's Avatar
Sorry for not being clear, the rod housing bore is larger and the crank is larger for most of the D-16 VS the D15, get the correct parts. The cylinder bores are the same.
Old Mar 6, 2004 | 03:39 PM
Burke's Avatar
Banned
oh ok thanks!!!
much appreciated
1point7db2
Mar 29, 2006 10:10 AM
SOHCD16y8
May 21, 2005 12:32 AM
v4lu3s
Jul 26, 2004 11:25 AM
PM-Performance
May 28, 2003 10:02 PM
