Rear camber problems
Old Mar 6, 2004 | 07:28 AM
tekkynikality's Avatar
Default Rear camber problems
i'm lowered about 2 inches on B+G full coilovers. i've gotten an alignment for my poor negative camber, but the top of the wheel still remains tilted in.
the treadwear is fairly bad, and i get a lot of road noise. i tried the "washer trick" and even put in 5 washers between the rear upper control arm bolt and the well wall.
it really did nothing. so i'm wondering about whether or not i should just go buy a rear camber kit, because i cant afford to have sets of tires wear unevenly like this.
i was hoping the washer trick would work, but it didn't and i need some tips on what to do. thanks.
Old Mar 6, 2004 | 07:30 AM
uNF$@#!'s Avatar
Default Re: Rear camber problems (tekkynikality)
you answered your own question?
gotta pay to play and its time for you to pony up
Old Mar 6, 2004 | 07:37 AM
akeldama's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekkynikality &raquo;</TD></TR><TR><TD CLASS="quote">i'm lowered about 2 inches on B+G full coilovers. i've gotten an alignment for my poor negative camber, but the top of the wheel still remains tilted in.
i was hoping the washer trick would work, but it didn't and i need some tips on what to do. thanks.</TD></TR></TABLE>
You do know the alignment shop cannot adjust camber without you having a kit, right? I have never seen the washer trick not work for anyone. Have you checked for bent suspension pieces?
Old Mar 6, 2004 | 08:02 AM
Default Re: Rear camber problems (glassjaw)
i didn't know that. maybe that's why the shop guys said they couldnt do it any more thanks for the info, i'll check for bent pieces.
Old Mar 6, 2004 | 08:50 AM
jetydosa's Avatar
25 Year Member
What is your toe set at?
Old Mar 6, 2004 | 09:23 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
I suspect that your toe is off and that's what causes the uneven tire wear.
bimmeris
Jul 14, 2008 10:28 PM
FalkenSiR
Suspension & Brakes
Jun 6, 2006 11:06 AM
Dooley
Suspension & Brakes
Oct 7, 2005 08:28 PM
9civic8
Suspension & Brakes
13
Aug 29, 2005 05:01 PM
9crx1
Jun 16, 2004 11:10 AM
