b16 exaust manifold same size as b18c5?
Old Mar 6, 2004 | 06:12 AM
denshu's Avatar
Default b16 exaust manifold same size as b18c5?
i need to know if the stock jdm b16 exuast manifold if it's a little smaller then the type R....i've already searched didn't find anything about size.
i got a usdm type r header, just seeing if i should change only the downpipe instead of changing the whole thing if it's the same size.
thanks in advance
Old Mar 6, 2004 | 11:57 PM
Rusty Shackleferd's Avatar
Default Re: b16 exaust manifold same size as b18c5? (denshu)
the b16 manifold is shorter than a gsr and type r
if you try to put a b16 man on a b18c it will hit the oil pan
b16 have a shorter deck height
b18c motors have a deeper oil pan because of the 3 main gurtle also
You can use a type r header on a b16......... just not the other way around
Old Mar 7, 2004 | 07:37 AM
denshu's Avatar
Default Re: b16 exaust manifold same size as b18c5? (10secondbeast16)
i knoe the b16 exaust manifold is short...but it fits on my gsr but very very tight fit...
i just need to know if the diameter size of the type R is bigger then the b16 header
thanks
Old Mar 7, 2004 | 11:03 AM
Do you mean the collector?
Old Mar 7, 2004 | 12:54 PM
denshu's Avatar
no..the overall diameter
usdm header-2 1/4?
jdm 4-1 header- 2 1/2?
jdm b16 header- ????? that is the question
WhiteVX
Jun 15, 2006 06:43 AM
juanb
Jul 10, 2005 07:15 PM
Leisyman
Nov 11, 2002 06:25 PM
