camber kits
Old Mar 5, 2004 | 09:25 PM
af97civic's Avatar
Default camber kits
i am confused,i lowered my car approx. 3''.i am looking at some kits and there are some kits that range from -1 to+4 degrees,i don't understand what that means. could someone tell me what specs. i will need to fix it.
Old Mar 6, 2004 | 12:06 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: camber kits (af97civic)
go to an alignment shop, have them spec out your settings, ask for advice, and see how many degrees you need to correct. i am running over 2 degrees on front and back and everyone i talked to agreed that camber adjusting is not needed.
stan
Old Mar 6, 2004 | 12:29 AM
2kstreetcivic's Avatar
Default Re: camber kits (Stan D)
ya, take it to a shop..the will tell you the degrees you are out of camber then you can adjust it to that degree and your tires will be straight again..good luck
rrodriguez
Honda CR-V & Element
Jul 31, 2018 05:37 PM
k215
Honda Civic (2006 - 2015)
Mar 19, 2010 03:03 PM
lowezz
Nov 18, 2004 10:14 AM
