Transmission question
Old Mar 5, 2004 | 08:27 PM
AsianMullet's Avatar
Default Transmission question
I recently just got my clutch installed on my gsr. Didnt ask if he filled the transmission fluid but it keeps popping out of 5th gear on the highway....could low transmission fluid be the problem?? how many quarts to fill the tranny anyways? Thanks for your help.
Old Mar 5, 2004 | 09:01 PM
Kendall's Avatar
I wouldn't rule it out, but it shouldn't pop out due to lack of tranny fluid. Of course you can always check your tranny fluid and find out if that's the problem.
Old Mar 6, 2004 | 12:04 AM
InjectedPerformance's Avatar
We sell parts.
Default Re: Transmission question (EKchump)
Yes! It is lack of oil in the tranny!
Old Mar 6, 2004 | 09:24 AM
acy76's Avatar
Default Re: Transmission question (primo8998)
Low fluid can cause this problem.
Old Mar 6, 2004 | 10:40 AM
2kstreetcivic's Avatar
Default Re: Transmission question (acy76)
yes, you could have low fluids...just check them and you should be fine
Old Mar 11, 2004 | 12:01 AM
trialoner's Avatar
Default Re: Transmission question (2kstreetcivic)
I wish I would of known to check my tranny fluid when my car jumped out of gear... Now my tranny is toast... But, b16a1 tranny on the way for my b18!!
yay...
Old Mar 11, 2004 | 08:32 AM
turbodGSR's Avatar
Default Re: Transmission question (trialoner)
i dont think low fluid would cause that, sounds like the ring on the fifth gear blocking ring is toast.
Old Mar 31, 2004 | 03:23 PM
deepbluepentium's Avatar
I could be several things. First of all b series trannys dont use transmission fluid. You would have to use 10w-30 (the same as your motor). If it pops out on the freeway and its not an oil factor it can be one of your synchronizers. If later on 4rth gear is giving you problems then its your synchros. If you lack oil or the right oil then you probably just wore out your 5th gear and it will need replacing. Check your oil if you change it on your tranny and look for metal flake (tiny chunks of metal). Or could be your housing. Ive had just about every problem with honda trannies so just keep in touch and let me know what else you find wrong. Oh yeah one more thing if you took your car to get a clutch then the mechanic would have to been really really forgetful to forget to put oil in your tranny.
Old Mar 31, 2004 | 03:49 PM
We sell parts.
Default Re: Transmission question (deepbluepentium)
it is deff. Low on tranny oil!
Old Mar 31, 2004 | 04:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primo8998 &raquo;</TD></TR><TR><TD CLASS="quote">it is deff. Low on tranny oil!</TD></TR></TABLE>
Yup...tranny oil was dry......pennzoil syncromesh works good !
Old Mar 31, 2004 | 05:10 PM
Mr Boston's Avatar
Good thing u noticed it
Rikaro
10
Jun 6, 2007 04:38 PM
T Rick
Sep 10, 2006 10:03 PM
FLCivic
10
Apr 14, 2004 07:19 PM
AcuraRacer112
Mar 23, 2002 01:05 PM
Chip398193
Oct 23, 2001 01:47 PM
