Torque specs on AEBS head studs
Old Mar 5, 2004 | 08:15 PM
kaj's Avatar
kaj
Default Torque specs on AEBS head studs
no info found via search... does anyone know? i'm assuming it's not going to be the same as the stock bolts, or is it?
also, any special tricks or tips i should know before putting them in?
thanks
Old Mar 5, 2004 | 08:59 PM
Kendall's Avatar
Should be the same as stock. Contact earl, he'll know, or just call AEBS on Monday.
Old Mar 5, 2004 | 10:41 PM
kaj's Avatar
kaj
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Should be the same as stock. Contact earl, he'll know, or just call AEBS on Monday.</TD></TR></TABLE>
:werd: sounds good. thanks.
Old Mar 6, 2004 | 12:38 AM
mh's Avatar
mh
Default Re: (kaj)
torquing a nut(studs) and torquing a bolt is diffrent. you'll need lees torque on the nut than on the bolt to get the same clampingforce. i'd say about 10% diffrence,but then that's only a rule of thumb......
Old Mar 6, 2004 | 11:17 AM
kaj's Avatar
kaj
Default Re: (mh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mh &raquo;</TD></TR><TR><TD CLASS="quote">torquing a nut(studs) and torquing a bolt is diffrent. you'll need lees torque on the nut than on the bolt to get the same clampingforce. i'd say about 10% diffrence,but then that's only a rule of thumb...... </TD></TR></TABLE>
that's what i was thinking... i couldn't see how they would be exactly the same. i'm planning on just calling AEBS on monday.
thanks guys.
Old Mar 8, 2004 | 10:44 AM
kaj's Avatar
kaj
for anyone needing to know:
AEBS headstuds are to be torqued 10 over the OEM final setting for head bolts.
this info is direct from AEBS.
nowhere could i find a post where anyone listed an answer to the question, so there ya go.
lilsicsoul
13
Feb 15, 2010 12:43 PM
85ZC
Sep 28, 2008 08:18 AM
crnimacak
15
Nov 25, 2007 09:56 PM
g1zcteg
Oct 26, 2005 11:21 AM
G-reX
Oct 6, 2003 04:55 PM
