str intake manifold
Old Mar 5, 2004 | 05:11 PM
ramennoodles's Avatar
Default str intake manifold
my b18b str intake manifold keeps bringing up an ecu code related to the iac valve, I've tried to contact str but it didn't help. anybody else out there having this same problem? I've been searching this site for iac, and see people talking about bypassing water on the iac, would this stop the codes from coming up?
Old Mar 5, 2004 | 05:16 PM
Default Re: str intake manifold (600gixxer)
Old Mar 5, 2004 | 07:17 PM
anybody there?
Old Mar 6, 2004 | 09:21 AM
rtype11's Avatar
think the IAC just might be clogged/dirty, remove and clean out the filter mesh, try sensor safe brake parts cleaner maybe.
Old Mar 6, 2004 | 10:01 AM
BDL IND's Avatar
Default Re: str intake manifold (rtype11)
What exactly is happening? Sometimes when installing the IAC you can pinch the o-ring, which can causde a vacuum leak, which may cause you to throw a code. YOu may also have a faulty/BAd IAC.
Old Mar 6, 2004 | 04:04 PM
Default Re: str intake manifold (STR)
It only started when I put the str intake manifold on. I pulled the iac cleaned and checked the o-ring then put back on. it didn't help. check light only comes on sometimes, shuting off motor and restarting sometimes stops it.
Old Mar 6, 2004 | 04:07 PM
and also when the check light comes on, the car idles at about 1300 rpm
Old Mar 6, 2004 | 04:23 PM
mmuller's Avatar
Mad Scientist
switch the iac with a known working one and see
Old Mar 8, 2004 | 07:49 PM
BDL IND's Avatar
Default Re: str intake manifold (mmuller)
Yes, make sure the IAC is working correctly. Does the Idle bounce around at all? At low RPM. All the hoses are plugged back in?
Old Mar 9, 2004 | 06:05 PM
jrcrx's Avatar
When you installed the the intake manifold did you put back the proper plugs into it proper place. I did that once, when I dropped a b18 in to my civic and switched the water temp plug with the iac and I got the same code as you did, check and double check if not replce the iac!
Old Mar 18, 2004 | 10:40 AM
Default Re: str intake manifold (jrcrx)
took out iacv again and cleaned it real good, put it back and still got a check code. then when I was driving around one of those water hoses started leaking. a my car ran out of water/antifreeze, and ran really hot for few minutes until I could get to a water faucet. fixed the hose, added water with no antifreeze and drove home. now the car doesn't bring a check code anymore and runs just fine now. could it have been the type of antifreeze I was using? I was using the red color stuff, the one that says 150,000 miles on it
Old Mar 18, 2004 | 02:10 PM
dfoxengr's Avatar
WOW u can only use green antifreeze in hondas, the pink is WRONG
Old May 1, 2004 | 11:14 AM
TurboTeG4's Avatar
Default Re: str intake manifold (hybridvteceg)
Did you throttle cable connect up find usin that manifold?
Old May 2, 2004 | 09:27 PM
THEredDEVIL's Avatar
Default Re: str intake manifold (TurboTeG4)
how much did you pay for the str intake manifold?
vj30
Honda CR-V & Element
Aug 31, 2015 05:47 PM
Honda Bull
May 29, 2006 11:56 AM
1TwistedEG
Apr 2, 2005 10:43 AM
TurboB18C1
Jun 6, 2004 05:57 PM
ramennoodles
Jan 21, 2004 07:20 PM
