breaking down an R motor
Old Mar 5, 2004 | 04:50 PM
SPOONfdEK's Avatar
Default breaking down an R motor
OK guys i'm gonna give you a quick run down of my situation. I'm currently running a JDM B18C type R motor in my EK. This is the second motor that i get that smokes like a *****. The motors have both been Super clean inside and out, but i still get the whitish smoke mostly on deceleration. I have done my research and I have come to the conclusion that its my valve stem seals. Here is where i need your advice, I'm thinking of going into the motor to clean out my rings and replace old bearings etc... Since i am going to pull the head off I was thinking of maybe doing some mild porting. I have a friend that knows how to port but then again he's no EXTRUDE HONE or anything like it. Will a mild porting and cleaning up be to any advantage. I dont have the $$ to send out the head and match it up with a set of cams. I was thinking of getting a good headgasket, rod bearings and valve stem seals, but I dont know what to go with. TIA
Old Mar 5, 2004 | 10:20 PM
1 2 NV's Avatar
Default Re: breaking down an R motor (SPOONfdEK)
if this so called friend doesnt do the porting for a living and/or doesnt have a flowbench sittin in his garage to prove his techniques i say ur better off leavin it stock. ITR heads arent bad bone stock. leave it and save the money for something thats goin to get done right.
Old Mar 5, 2004 | 10:28 PM
NW94RS
Guest
Posts: n/a
Default Re: breaking down an R motor (1 2 NV)
I couldn't agree more
Old Mar 6, 2004 | 10:49 AM
FOrSfEd's Avatar
Default Re: breaking down an R motor (nw94rs)
I would just keep it like it is.
91_civicsi
Jan 14, 2010 11:29 PM
neiler3
Oct 20, 2006 08:28 PM
SQ is the SQUAD
Oct 26, 2005 10:56 AM
Honda Kustums
14
Aug 27, 2003 07:33 AM
maxxdout
Sep 24, 2002 12:36 PM
