Cams in F22
Old Mar 5, 2004 | 04:17 PM
DrewQ1's Avatar
Default Cams in F22
i was told if you adjust your cams or replace your cams you can get your power to react more quickly at lower rpms then at the higher. Is this true? also what kind of cams are good? Would I need cam gear or the cam pulley or whatever, cause i looked at this website for cams and i just see a sprocket. Help me out thanks.
Old Mar 7, 2004 | 05:04 PM
DrewQ1's Avatar
Default Re: Cams in F22 (DrewQ1)
can anyone help me?
Old Mar 8, 2004 | 05:09 AM
Daemione's Avatar
I'm not aware of anyone who offers a cam for the F22 (SOHC, I assume). You'd have go get a custom grind through Crower or Webcams or someone.
But how your powerband will be affected depends on the specs of the cam profile.
Old Mar 31, 2004 | 10:26 AM
Teal95Coupe's Avatar
sprocket is just another word for gear.
Old Mar 31, 2004 | 01:05 PM
ZigenBallz's Avatar
Default Re: Cams in F22 (Teal95Coupe)
lots of companies do regrinds for F22's.... and it's CAM BTW no plural on a SOHC...
most people get regrinds to move the powerband up... F22's have more than enough low end grunt...
Old Mar 31, 2004 | 05:45 PM
TOM J's Avatar
Old Schooler
Talk to Bisi he has cams for these f22s
threehonda
K Series
Dec 20, 2009 06:37 PM
DrewQ1
Mar 7, 2004 05:03 PM
