ITR and GSR clutch disc / pressure plate... the same?
Old Mar 5, 2004 | 11:20 AM
danny98r's Avatar
Default typeR oem clutchdisc/pressure plate the same as gsr?
just want to know if these parts are the same.
Old Mar 5, 2004 | 11:39 AM
.RJ's Avatar
.RJ
Default Re: typeR oem clutchdisc/pressure plate the same as gsr? (danny98r)
I do not think they are the same.
Old Mar 5, 2004 | 11:45 AM
Opie's Avatar
My friend is running a ITR clutch and PP in his GSR w/o problems. The clutch plate is the same between the two not sure of the pressure plate though.
Old Mar 5, 2004 | 11:52 AM
thk's Avatar
thk
Members Only
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">My friend is running a ITR clutch and PP in his GSR w/o problems. The clutch plate is the same between the two not sure of the pressure plate though. </TD></TR></TABLE>
Different part numbers.
You can use the ITR OEM clutch on other B series and vice versa but supposedly, the ITR clutch is the best OEM clutch (from Honda) available and a reason why a lot of people opt for the ITR one when replacing non ITR clutches.
Old Mar 5, 2004 | 12:05 PM
vtec.dc2's Avatar
i think itr is 1500lbs pressure plate, and gsr would have to be less, i'm not sure about the clutch disk, bearing should also be the same, and flywheel is lighter.
spoonek4
Mar 18, 2006 12:03 AM
Qwikrex
Jan 1, 2003 12:57 AM
B18C
Aug 8, 2002 07:07 PM
Audipwr1
Apr 29, 2002 02:46 PM
