B16A Intake Manifold to 1.6i DOHC (ZC) engine like D16A9
No it and any other B-series manifold will not bolt up, and from what I understand, neither will any other D-series manifold.
Between the B and D series motors, there isn't much interchangeability. The ZC motor is kind of the in-between motor, not quite a B-series, and different from most other D-series.
Only other engine that shares a DOHC ZC intake pattern was the older interga motor. But why would you swap a intake that flows 28% less than the ZC intake (but that was known as the BROWN top ZC).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dochmees »</TD></TR><TR><TD CLASS="quote">Hard to believe, because they definitely look the same and generally Honda parts will fit quite widely.</TD></TR></TABLE>
then why don't you try it?
i highly doubt it will fit but this is just speculation
pelotudo
Mar 2, 2003 05:55 PM
