is this honed correctly???
Old Mar 4, 2004 | 08:53 PM
kaj's Avatar
kaj
Default is this honed correctly???
i honed my cylinder today. sorry the pics are so big, but i need to show the detail. how does it look? i tried to get the 45-60 deg cross-hatch. thanks.
Old Mar 4, 2004 | 10:09 PM
JDMorgan's Avatar
thats ball honed? could you give more info no how you did it? i may need to throw together a beater motor.
Old Mar 4, 2004 | 11:40 PM
kaj's Avatar
kaj
Default Re: (KraZEtEggIE)
no. only hone i had was the one with the three stones. i TRIED to get a ball one. i'm told they are better for hatching.
the motor only has about 50k miles on it, i'm guessing by the looks of it. all i needed to do was remove the glazing.. kinda freshen everything up. i just want to be sure it is right.
if not, i will redo it before i put it together.. .. i just have nobody answering yet as to whether or not it looks right..........?
Old Mar 4, 2004 | 11:44 PM
wHOAlly's Avatar
Default Re: (kaj)
did u do it dry?
Old Mar 5, 2004 | 01:50 AM
OTT's Avatar
OTT
It looks like you didnt feed any kind of cutting lube in there, did you do it still with the crankcasebelow like in the picture?
Old Mar 5, 2004 | 02:01 AM
JDMorgan's Avatar
you just use normal lube like ur millin up a fuel rail or somethin?
Old Mar 5, 2004 | 05:58 AM
MightyMouseTech's Avatar
Default Re: (Sp00n'd Supra)
That looks nasty. I usually just use Wd-40 to lube the hone, works pretty damn well. Did you remove the crank and oil squirters when you honed it? You are gonna break off a squirter if you keep doing it like that, and/or damage the crank.
Old Mar 5, 2004 | 10:11 AM
kaj's Avatar
kaj
Default Re: (MightyMouseTech)
everything was out. i used a GRIP of WD-40.. a GRIP. maybe i should have sprayed it continuously while i was honing?
Old Mar 5, 2004 | 11:11 AM
SMSP's Avatar
Default Re: (kaj)
p/s fluid works well
Old Mar 5, 2004 | 11:15 AM
kaj's Avatar
kaj
Default Re: (SMSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">p/s fluid works well</TD></TR></TABLE>
i've heard that. i'll see if i have some. how 'bout brake fluid?
Old Mar 5, 2004 | 11:35 AM
mmuller's Avatar
Mad Scientist
Default Re: (kaj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaj &raquo;</TD></TR><TR><TD CLASS="quote">
. how 'bout brake fluid?</TD></TR></TABLE>
no
Old Mar 5, 2004 | 12:30 PM
dmotoguy's Avatar
Default Re: (mmuller)
brake fluid = BAD
Old Mar 5, 2004 | 01:30 PM
kaj's Avatar
kaj
Default Re: (dmotoguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmotoguy &raquo;</TD></TR><TR><TD CLASS="quote">brake fluid = BAD</TD></TR></TABLE>
okay, i assumed so. good. just checking 'cause it surprised me that p/s fluid would work.
next question: is the cylinder so bad that i won't be able to save it? i'm going to work on it tonight and want to be sure that i hone JUST enough to fix it right.
Old Mar 5, 2004 | 01:50 PM
kaj's Avatar
kaj
Default Re: (kaj)
also: should it still be somewhat shiny?
Old Mar 5, 2004 | 06:37 PM
myhatchrips's Avatar
Default Re: is this honed correctly??? (kaj)
sunnen honing oil is what you should have used.
Old Mar 5, 2004 | 07:49 PM
HumanResource's Avatar
Honing while crank still in block???
Old Mar 5, 2004 | 08:16 PM
kaj's Avatar
kaj
Default Re: is this honed correctly??? (HumanResource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource &raquo;</TD></TR><TR><TD CLASS="quote">Honing while crank still in block??? </TD></TR></TABLE>
see above post
Old Mar 5, 2004 | 08:41 PM
bretx0r's Avatar
its hard to rehone and use the same bore because you might not get the proper piston-wall clearence, which means a bigger gap in the rings which means more blowby. It is best to get it honed on a machine and get overbore pistons each time you re-ring because when doing a ball hone there will be not a perfectly flat contact patch and that will develop hot spots in the sleeves which could result in early cracking if temps get too high. Make sure you hone with 800 grit or you might not get proper seal with the rings.
Old Mar 5, 2004 | 10:45 PM
kaj's Avatar
kaj
Default Re: is this honed correctly??? (bretx0r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bretx0r &raquo;</TD></TR><TR><TD CLASS="quote">its hard to rehone and use the same bore because you might not get the proper piston-wall clearence, which means a bigger gap in the rings which means more blowby. It is best to get it honed on a machine and get overbore pistons each time you re-ring because when doing a ball hone there will be not a perfectly flat contact patch and that will develop hot spots in the sleeves which could result in early cracking if temps get too high. Make sure you hone with 800 grit or you might not get proper seal with the rings. </TD></TR></TABLE>
all ring gaps were well within tolerance. i wasn't able to find a ball hone, had to use the one with the three stones, did just enough to take off the glazing. had a guy come look at the honing. he's a master mechanic for honda. says it looks fine. showed him the pictures i posted above.. apparently the flash makes the cross hatches look worse than they are.
motor is put back together. we'll see how it goes on monday. that should be when i fire her up again.
i'm sick. gonna rest 'till monday.
rmercado
Apr 18, 2010 08:36 AM
Voodooboy520
Jan 18, 2006 11:54 AM
usdm420
Honda Motorcycles
15
May 2, 2005 11:04 AM
MK Ultra
Nov 13, 2003 04:02 PM
1bar
Jul 7, 2003 06:10 AM
