ls chipped ecu question need help
Old Mar 4, 2004 | 08:02 PM
96tegls's Avatar
Default ls chipped ecu question need help
i have a stock ls block and a head with crower valvesprings and retainers, web cams, .395 valve lift, 242 duration, duration at .050 in degrees is 222. Bling chrome dipped valve cover. z speed adjustable cam gears, very clean P&P, 3 angle valve job,will also being runin s-afc, arp rod bolts and head studs. i want it to red line higher then stock so what should i get for a chipped ecu with thsi set up. im lost in the chipped ecu department if someone could please help me out. thanks
Old Mar 6, 2004 | 07:06 PM
96tegls's Avatar
Default Re: ls chipped ecu question need help (96tegls)
ttt please someone
Old Mar 6, 2004 | 08:24 PM
HRTuning's Avatar
IM me and I'll go over a few things with you... SN: HardLowrdRanger
Old Mar 7, 2004 | 02:10 PM
yimmy's Avatar
Default Re: ls chipped ecu question need help (HardLowrdRanger)
Bump for a local gangsta.
hatchyAllday
Northeast (Sales)
10
Nov 2, 2008 10:49 AM
b20ek
Dec 22, 2004 10:15 AM
drewbie*
Mar 26, 2004 07:27 AM
