Do B16 heads come like this
Old Mar 4, 2004 | 08:01 PM
Rod.'s Avatar
Default Do B16 heads come like this
they all have missing exhaust side stud. Every head I find, do they come like that or people are breaking them?
Old Mar 4, 2004 | 08:27 PM
R6Boy69's Avatar
Default Re: Do B16 heads come like this (redturbocivic)
Newer motor come like this, not sure what year honda made the change though...
Old Mar 4, 2004 | 08:28 PM
warchild69's Avatar
hey on all the b-16 heads...... they come with bolt and stud combo's.... the one in the photo is what you should get....... that is a good looking head if i say do myself.... where are you buying from... and how much$$$.... im in the market for one for my crvtec setup i will start soon! but yea that is normal...
Old Mar 4, 2004 | 08:39 PM
Rod.'s Avatar
Default Re: Do B16 heads come like this (warchild69)
Cant tell where im getting it from. I want to get one real bad. Wouldnt that cause an exhaust leak with jsut two studs bolt up?
Old Mar 4, 2004 | 09:29 PM
Sliced Beard's Avatar
no, dude you have to use bolts ont he rest of the holes
Old Mar 4, 2004 | 10:07 PM
JDMorgan's Avatar
obd 2 uses 2 studs to get the header in the right lpace and bolts all the way around. i just learned this last week. good way to tell if the block is from a 99-00 si tho along with a couple other things to check(like the date on the cast.) alot of people dont show the dates in their ebay auctions tho.. mine had 2 studs and ups threw the head so both were bent.
Old Mar 4, 2004 | 11:24 PM
Rod.'s Avatar
Default Re: (KraZEtEggIE)
thanks I just learned something about the 99-00 si heads. Anyone know the bolts size by heart that go in there?
Old Mar 4, 2004 | 11:58 PM
JDMorgan's Avatar
if i was you id buy from honda. less **** to go wrong.
jdmdikk
Dec 5, 2008 07:53 AM
Boostedb20EH2
Mar 24, 2007 04:17 PM
X-Static
May 23, 2004 10:58 AM
