how much whp can my setup produce once tuned?
bottom end:
2000 b18c5 overbore .020
81.5 mm
wiseco 11:8 pistons
eagle i-beam rods
arp rod bolts
balanced/micropolished ls crank
gsr oil pump
gsr water pump
gsr timing belt
head:
98 gsr head fully ported and polished by Portflow
rocket valvetrain
m24x cams
jg cam gears
oem valve seals
skunk 2 intake manifold
ported gsr throttle body port matched to skunk manifold
exhaust:
bisimoto header
2.5 test pipe
2.5 inch kteller mandrel bent piping with 22 inch resonator with es muffler
fuel:
310 cc injectors
255 lph walbro fuel pump
ericks racing fuel pressure regulator
marshall fuel pressure gauge
ecu:
chipped p28 5700 vtec with a 9500 rpm rev limit
hondata s200
transmission:
jdm gsr tranny with 4.7 final drive
hyperclutch 6 puck
im estimating at least 205 whp once tuned. what do you guys think? all inputs would be greatly appreciated.
81.5 mm
wiseco 11:8 pistons
eagle i-beam rods
arp rod bolts
gsr oil pump
gsr water pump
gsr timing belt
head:
rocket valvetrain
m24x cams
jg cam gears
oem valve seals
exhaust:
bisimoto header
2.5 test pipe
fuel:
310 cc injectors
ecu:
hondata s200
transmission:
hyperclutch 6 puck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manuel »</TD></TR><TR><TD CLASS="quote">PM sent</TD></TR></TABLE>
LuckyToBeBC
Southeast (Sales)
37
Aug 23, 2010 12:44 AM
