Does any body think this is a good set-up?
Old Mar 4, 2004 | 05:00 PM
Gimp's Avatar
Default Does any body think this is a good set-up?
I am running a D16A6 with the following mods:
aem cold air intake
aem pully kit
new timing belt
block was resurfaced and cylinders were honed
valve seals
new oem intake and exhaust valves
new head gasket
ported and polished head
unorthodox st-r cam gear
crane stage 2 camshaft
pace setter header
bigger radiator
msd sport compact ignition with street blaster ss coil
new water and oil pumps
act stage 2 clutch with h/d pressure plate
free flow exhaust
zc throttle body
as for suspension:
kyb adjustables with lowering springs
front and rear upper strut bars
brembo drilled, slotted, and zinced plated rotors
I recently purchased some new rims and tires as well.
So what do you think? This is the first engine I have built. Feedback would be greatly appreciated.
Ryan
Old Mar 4, 2004 | 05:10 PM
marieT1GRL's Avatar
Default Re: Does any body think this is a good set-up? (Gimp)
i would get rid of the pace setter header and find something better (DC)... as for your cam, (crane stage2), did you upgrade your valve springs?.. besides that, everything looks good... good luck
-marie
Old Mar 4, 2004 | 05:12 PM
Gimp's Avatar
Default Re: Does any body think this is a good set-up? (ThatOneGirl)
I'm not fond of the header at all. But it was on the car when I bought it. I need to upgrade the springs too.
Old Mar 4, 2004 | 05:15 PM
marieT1GRL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gimp &raquo;</TD></TR><TR><TD CLASS="quote"> I need to upgrade the springs too.</TD></TR></TABLE>
if you didn't but them from crane yet, contact ROCKET, good stuff
-marie
Old Mar 4, 2004 | 05:23 PM
dfoxengr's Avatar
its alright i guess, i mean for your first motor at least u dove in and hit someinterna ls, get pistons
Old Mar 4, 2004 | 05:29 PM
infinatenexus's Avatar
Why do you think you need a bigger radiator?
bertsb18hatch
Nov 28, 2007 10:11 AM
bigz187
Mar 19, 2006 06:28 PM
Tiferet
Mar 4, 2005 07:52 PM
GreaseYankeedragger
Apr 1, 2004 09:38 PM
