ITR LSD in a GSR trans?
Old Mar 4, 2004 | 04:16 PM
97SpecR's Avatar
Default ITR LSD in a GSR trans?
Will an ITR LSD fit in a GSR trans?
Old Mar 4, 2004 | 04:31 PM
Dan GSR's Avatar
Default Re: ITR LSD in a GSR trans? (97SpecR)
yes
if you do a search you should find lots of info
if u have more questions , post, i'll try my best to answer them
Old Mar 4, 2004 | 04:56 PM
97SpecR's Avatar
Default Re: ITR LSD in a GSR trans? (Dan GSR)
With no problem at all? Anything different I would have to repl?
Old Mar 4, 2004 | 04:59 PM
Dan GSR's Avatar
may need to replace the shim to get the proper clearanc
otherwise its a drop in procedure
Old Mar 4, 2004 | 05:27 PM
SlapSmak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">may need to replace the shim to get the proper clearanc
otherwise its a drop in procedure</TD></TR></TABLE>
you will need to replace the shims to set the preload on the differential.. other than that you will need to do nothing else except maybe replace the bearings (which i would definately do)...
Old Mar 4, 2004 | 06:39 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97SpecR &raquo;</TD></TR><TR><TD CLASS="quote">With no problem at all? Anything different I would have to repl?</TD></TR></TABLE>
search will help you...
Old Mar 4, 2004 | 11:51 PM
sgT's Avatar
sgT
Default Re: ITR LSD in a GSR trans? (SlapSmak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlapSmak &raquo;</TD></TR><TR><TD CLASS="quote">
you will need to replace the shims to set the preload on the differential.. </TD></TR></TABLE>
Not all bearings require a preload.
Old Mar 4, 2004 | 11:57 PM
ek4hatch's Avatar
Default Re: ITR LSD in a GSR trans? (sgT)
yes it is possible
EGfosho
Feb 12, 2007 09:04 PM
Ruben19
Jan 15, 2007 06:19 PM
1QwIkEf
Oct 9, 2006 09:15 PM
Dan GSR
Feb 26, 2004 07:38 PM
BLK99VTECR
Jan 6, 2004 08:40 AM
