Can you resurface the friction ring on a Clutchmasters flywheel?
You can get a replacement for 100$, vs a 30-50 dollar resufacing. I would (and am) buying a replacement just for peace of mind
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges »</TD></TR><TR><TD CLASS="quote">You can get a replacement for 100$, vs a 30-50 dollar resufacing. I would (and am) buying a replacement just for peace of mind</TD></TR></TABLE>
Actually, you should even be able to find the replacement for quite a bit less than $100, making the cost difference between a traditional resurfacing and a brand-new surface more or less negligible.
if you happen to know where to buy them.....please post. its about that time for mine and am now in the market.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
Actually, you should even be able to find the replacement for quite a bit less than $100, making the cost difference between a traditional resurfacing and a brand-new surface more or less negligible. </TD></TR></TABLE>
I talked to clutchmasters, they said that you can take 3 thousandths off safely, but not more than that. That is enough to get the glaze off the friction ring
I wouldn't recommend it. If you run an indicator on a new insert you will notice that it is not flat. It has high spots between the bolts. These high spots flatten out a bit with the load of the clutch. They can get much higher when the insert is overheated and warps. If you grind the surface flat, the places between the bolts become low spots (under clutch load), instead of high spots... How about a economical solid chrome-moly XACT flywheel? Sorry, shameless plug!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AL ASPIRATED »</TD></TR><TR><TD CLASS="quote">the cheapest i found was $80 at GTM Performance, in Daly City, CA.
but i needed it quick and wasnt sure if they could had got it to me on time.
so payed the little extra</TD></TR></TABLE>
I get them for $50
I get them for $50
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR »</TD></TR><TR><TD CLASS="quote">
I get them for $50
where?
I get them for $50
</TD></TR></TABLE>where?
I get them for $50
$50 is a hella good *** deal, dats below most shops cost
I get them for $50
</TD></TR></TABLE>$50 is a hella good *** deal, dats below most shops cost
ill buy one....hell ill buy two<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR »</TD></TR><TR><TD CLASS="quote">local shop hooks me up.
edit: back on topic.. you CAN resurface the friction disc.
mysicivic1991
May 8, 2007 09:36 AM
1stGENGSR
41
Mar 20, 2005 11:01 AM
Ch33se
Mar 3, 2004 11:49 PM
