Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
fuel tank check valve
Old Mar 4, 2004 | 01:24 PM
Audipwr1's Avatar
Default fuel tank check valve
Building a custom fuel tank
Used to use vented fuel caps, but they suck
Does anyone know where to get a good check valve? I bought one from jegs but as you tip it over it leaks a little bit before it seals, that isnt acceptable for my rules, so i was hoping for a spring loaded one to make the tank be sealed unless a vacum occurs then the valve would open to equalize the pressure
sources?
Old Mar 4, 2004 | 05:51 PM
Littleton's Avatar
Default Re: fuel tank check valve (Audipwr1)
Hey, I'm not trying to slam you but please have a fire support system running when you decide to test your cell. If you are the master fabricator please excuse my comments.
To answer your question http://www.fuelsafe.com has one.
Good luck and please be safe with this.
Old Mar 5, 2004 | 08:42 AM
Audipwr1's Avatar
Default Re: fuel tank check valve (Littleton)
This is my third tank, and Im fairly adept with proper manufacturing processes, but thanks for the safety warning and the site.
Sprockets
May 4, 2017 07:22 AM
justinsbg
Jan 24, 2015 06:51 PM
egsickz0
Feb 10, 2011 07:52 AM
HamiltonRex
Jan 12, 2006 06:28 PM
