I need help bad, grind gear for prelude
took my car to the track ran i hard and missed 2rd, 3rd gear. now when i shift in 3rd gear and 5th gear at high RPM gear is kidda grind(only high RPM) can some one tell me what's wrong and what i can do to fix it. One more thing i have not change tranny fluid for a long time , u guys think this could be the problem THANKS
you ground the face of the gears of, now they will grind forever
I have done it to on older trannies of mine.. Be easy on these H22/H23 trannies, they don't like abuse, i learned this the hard way...
Change the fluid often! This will help with the gridining, use Honda MTF..
I have done it to on older trannies of mine.. Be easy on these H22/H23 trannies, they don't like abuse, i learned this the hard way...Change the fluid often! This will help with the gridining, use Honda MTF..
Wait but you guys think it could be the clutch cause i does not make any sound when i shift just the shift **** vibration u can feel it but it doesn't make noise
they are not going away even with a tranny rebuil?? and is it bad if i dont get it fix and just keep driving hard, is it gonna mess up my tranny
lol...
what you did WAS mess up your tranny. A tranny rebuild with different gears and synchros will fix all that ails you.
Keep driving it though, try not to ge too rough on her.
em1gangsta
Nov 11, 2008 12:30 AM
