Charcoal Canister?
Old Mar 4, 2004 | 07:56 AM
B-B-K's Avatar
Default Charcoal Canister?
In a week or so I plan on pulling my B16 out of my 91 CRX si and doing a lot of work to it. I figured since it was out I wanted to clean up the engine bay. I have noticed on other CRXs that they dont have that huge stupid looking charcoal canister. I read up on it in my Haynes and they say it takes the fuel vapor and returns it to the motor or fuel tank, something like that. I want it out. Is there any way I can do with out? Like bypass it?
Its that big ugly black thing about 3in to the left of the throttle body on the firewall.
Hope I explaioned myself well enough and you guys know what Im talking about.
Thanks
Matt
Old Mar 4, 2004 | 08:12 AM
Origin's Avatar
Default Re: Charcoal Canister? (B-B-K)
im not totally sure if you can remove it, but if someone infact does tell you that you cannot, it should be very easy to relocate to where you cannot see it.
Old Mar 4, 2004 | 08:17 AM
crx_88_si's Avatar
it's part of emissions control, expect to get a CEL and fail any emissions tests.
Old Mar 4, 2004 | 10:29 AM
kid-honda's Avatar
Well as somebody who doesnt have one and somebody who has done it to many cars it causes no problem just make sure you run a longer vaccume line from the firewall vent to the ground to keep unwanted fumes under the hood.
There is alot of crap you can remove if you dont have emmisions.
Old Mar 4, 2004 | 10:59 AM
xci_ed6's Avatar
Default Re: (kid-honda)
I was just about to ask about this
Old Mar 4, 2004 | 12:03 PM
HamiltonRex's Avatar
so pretty much what do i do to elminate this canister?
Just connect the 2 vacume lines that go into it?
I need to pass emissions, so should it stay put?
-Eric
Old Mar 4, 2004 | 12:09 PM
mikecivichb's Avatar
I dont have emissions. In my 89 dx hb. What kind of crap can I take out without the cel comming on. ttt
Old Mar 4, 2004 | 12:46 PM
RCautoworks's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">it's part of emissions control, expect to get a CEL and fail any emissions tests.</TD></TR></TABLE>
Why would you get a check engine light ? There is no sensor hooked up to it. You can remove the canister but if the emissions place checks for it, you fail.
Old Mar 4, 2004 | 12:56 PM
BAZ's Avatar
BAZ
Default Re: (90blackcrx)
Would removing the canister affect the car performance-wise?
Old Mar 4, 2004 | 01:03 PM
Default Re: (BAZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BAZ &raquo;</TD></TR><TR><TD CLASS="quote">Would removing the canister affect the car performance-wise?</TD></TR></TABLE>
No
Old Mar 4, 2004 | 01:08 PM
BAZ's Avatar
BAZ
So its just to clean up the engine bay basically
Old Mar 4, 2004 | 01:09 PM
Default Re: (BAZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BAZ &raquo;</TD></TR><TR><TD CLASS="quote">So its just to clean up the engine bay basically</TD></TR></TABLE>
Yep
Old Mar 4, 2004 | 02:34 PM
BAZ's Avatar
BAZ
werd.
Old Mar 4, 2004 | 02:44 PM
MonkeyMagic's Avatar
Default Re:
its part of the evorative emissions... dont **** with it if you can't figure out how to bypass it just by looking at the diagram on the bottom of the hood.
while your at it re-do your pcv and valve cover to intake breather with a home-made catch can! gets rid of all sorts of nasty stuff on the engine and around... if you do it right it won't throw codes
Modified by MonkeyMagic at 7:48 PM 3/4/2004
Old Mar 4, 2004 | 05:11 PM
Fobtions's Avatar
Default Re: Re: (MonkeyMagic)
If you have a newer motor there usually isnt a place to hook up the charcoal canister. look at my engine i only have one vacuum line which is the fuel pressure regulator and the brake booster.
just run the vacuum line down as was said up top.
Old Mar 4, 2004 | 06:59 PM
Thudpucker's Avatar
Think of it this way B-B-K!
"That's my air your polluting by leaving the cannister off!"
How would you like it if I did the same to your Mother, or your baby?
That Cannister has a very real function. Leave it there and leave it connected.
Old Mar 4, 2004 | 08:03 PM
krazie1's Avatar
BANNED
Default Re: Charcoal Canister? (Thudpucker)
listen to mother nature
well I got mine dissconnected
and threw it away
cuz it was nasty and a waste of space
The hell with Cali's smog crap
That is why I got peeps that can handle issues like that for me
That is why I can say stuff like that
LoL
Old Mar 4, 2004 | 08:41 PM
B-B-K's Avatar
Thanks for the reply Thudrucker. I hope you dont fart, that pollutes the air too you know. Im going to stop fartin just for you, and light a match everytime I drop a steamer.
Old Mar 4, 2004 | 08:46 PM
MrIllegalX's Avatar
sounds like a ghetto EGR valve
Old Mar 4, 2004 | 09:35 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyMagic &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by MonkeyMagic at 7:48 PM 3/4/2004</TD></TR></TABLE>
is there any write ups for this?
Old Mar 4, 2004 | 09:46 PM
ceLtic's Avatar
N/A wh0re!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thudpucker &raquo;</TD></TR><TR><TD CLASS="quote">Think of it this way B-B-K!
shut up queer. i have just as much of a right to pollute. stfu
ThefirstPACT's Avatar
Default Re: Re: (Hybrid Hatchback)
It is going to affect gas mileage as well! The fuel vapors that it puges back into your intake will no loger be burned again. So in the long run it will eventually wear away at yor pocket!
Old Mar 4, 2004 | 11:26 PM
CyniKal.Mindset's Avatar
Default Re: Re: (ThefirstPACT)
do like VW and relocate it to the fender well...no fuss no muss and outta sight!
Old Mar 5, 2004 | 05:14 AM
Thudpucker's Avatar
It appears we have a cadre of 'Rube Goldberg' modifiers who believe the SAE engineers at HONDA just dont know what they are talking about and aren't in the real world of the dismantlers and re-engineers.
The next project B-B-K can work on wiill be a Flatulance re-circulating device for the Bovine Quadroped's. Whose Flatulance is mentioned by some as the real danger to the Ozone layer.
Meanwhile, back in "want's to be important ville" B-B-K would be well advized to leave the Charcoal cannister in place. Paint it a nice shiny black if you want to, and hose it off once in awhile.
It works as advertized.
Does not affect performance in any way!
With it in place you wont have any 'flash fires' while in heavy stop n go traffic on a warm summer day.
And of course you wont have any problems with the Referee.
Old Mar 5, 2004 | 05:29 AM
Doctor CorteZ's Avatar
Default Re: (MrIllegalX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrIllegalX &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a ghetto EGR valve</TD></TR></TABLE>
how are these two items related in any way ?
do you even know what an EGR valve does ?
