question on sway bars for g2 gsr
Old Oct 16, 2001 | 07:23 AM
LethalX's Avatar
New User
Default question on sway bars for g2 gsr
I know there are other post about sway bars but i want one for my praticular car.
i have been hearing type R sway bar cuz its 22m or suspension techniques...
what do you all recommend? and what other parts will i need? bushing? anything to reinforce? because of some cases where tearing was evident...
good and bad...
thanks
Old Oct 16, 2001 | 07:30 AM
dplatt's Avatar
Default Re: question on sway bars for g2 gsr (LethalX)
I've got the Suspension Techniques Sway bars on my 92 GS. Made a huge difference. I have heard good things about the progress bar (22mm) as well as the new ADDCO bars. Best of luck.
Old Oct 16, 2001 | 07:40 AM
LethalX's Avatar
New User
Default Re: question on sway bars for g2 gsr (dplatt)
dplatt: off topic but where did u get those tails... i like the clear top and red bottom..
Old Oct 16, 2001 | 11:37 AM
dplatt's Avatar
They are APC clear tails that are painted with VHT Translucent Red Paint (code 232). I also painted the cheap looking chrome trim flat black.
Old Oct 16, 2001 | 02:28 PM
LethalX's Avatar
New User
up
Old Oct 16, 2001 | 02:51 PM
jonsteR's Avatar
I went with suspension techniques bars (F/R) on my G2 LS and am satisfied. Just have to lube those damn bushings again. Oh and they come with everything you need. You use your stock endlinks and brackets with them.
Old Oct 16, 2001 | 04:08 PM
Lyonel's Avatar
Where's the best place to get Progress and ST products from? I heard b17a.com is having some problems.
TIA
Old Oct 16, 2001 | 04:12 PM
jonsteR's Avatar
Default Re: question on sway bars for g2 gsr (Lyonel)
I got mine from JC whitney when they had the sale for 172 shipped. You can still get it from them but 229.95 front and rear. I do belive they have free shipping for items worth $200+ but it might just be for the US.
http://jcwhitney.com/item.jhtml?ITEMID=39787
don't know about progress.
Old Oct 16, 2001 | 08:13 PM
GSpeedR's Avatar
Default Re: question on sway bars for g2 gsr (jonsteR)
I will tell you how the Progress bar (22mm) is as soon as I go to Columbus to install it.
I would stick with the above mentioned brands.
Old Oct 16, 2001 | 09:01 PM
Slain's Avatar
Default Re: question on sway bars for g2 gsr (GSpeedR)
if you can get your hands on it i believe trust make a pretty beefy rear sway bar for the DA's... talking about it is one thing getting my grubby hands on one is another... alot of people have good experiences with ST and progressive so i'd probably go with that route
Old Oct 16, 2001 | 09:22 PM
DB2-R81's Avatar
25 Year Member
Default Re: question on sway bars for g2 gsr (Slain)
On my GSR I started with the stock rear Anti Sway bar 14.7mm, went to the automatic 4 door bar 15.9 mm, went to ST rear 19mm and I am now using the Progress 22mm bar. The progress bar out performs the ST bar in finish to stiffness except for its mounting and end link set up. The Progress bar fitment is much tighter at the exhaust bend over the rear control arm, be careful on what type of exhaust system you use. The mounting brackets must be carefully installed and reinforced. And the end links need to be replaced with adjustables to have a real good working system. One other thing, rear suspension droop is greatly restricted, so you will walking the dog in tight sweepers often if you Solo II with this set up. If you need more info let me know.
Old Oct 17, 2001 | 06:47 AM
LethalX's Avatar
New User
thanks for all the replies
im still undecided....
i was reading other post...
bsq kit for type R bar? does that involve welding? or is it just a bolt on as well... or whatever u call it.......
progress bar? what about that?
and where can i get the best prices ive seen a ST front and rear for anywhere from 220USD-280USD on the web.... anyone got a good site and trustworthy dealer i can call up or email? thanks
Old Oct 17, 2001 | 07:44 AM
dplatt's Avatar
Summit Racing sells them for $230 plus shipping. Great company to deal with, fast and reliable. Check them out....
http://www.summitracing.com
part no: STQ-52150
Old Oct 17, 2001 | 12:00 PM
Lyonel's Avatar
Default Re: question on sway bars for g2 gsr (DB1-R81)
DB1-R81 - So does the DA8 come with a 15.9mm swaybar? Any welding required/recommended with the Progress bar? Any pics u could share with us? TIA
There was a member on g2ic who managed to fit the ITR bar on his DA. Required some heavy welding and custom mounts though.
Old Oct 17, 2001 | 01:09 PM
LethalX's Avatar
New User
i called
its gonna cost me 229 plus 30usd for shipping to canada.. and taxes.. and he says its usualy gonna be about 30% holy @(#&(@#&@(&#!!!!!!!!! thats gonna be like 340USD... over 500 cdn... i hate taxes hmmmm
Old Oct 17, 2001 | 01:47 PM
jonsteR's Avatar
which sway bar(s) did you get?
Old Oct 17, 2001 | 02:23 PM
LethalX's Avatar
New User
im thinking im just gonna go wiht ST front and rear... i can get it for 500cdn for both... gst included...
ordering would end up costing me about 500 also because of the stupid taxes and duty and everyting else.. grrrrrrrrrr
Old Oct 17, 2001 | 02:48 PM
jonsteR's Avatar
yeah DAMN taxes.
anyway, i think the ST sway bars front and rear are the best to use without having to modify anything.
nico91civic
May 5, 2009 09:47 AM
VSM_EK
Jan 27, 2006 11:05 PM
hbgsr504
Jul 28, 2005 11:32 PM
krazyk
Suspension & Brakes
Apr 12, 2005 01:55 PM
ArizSun21
Jan 4, 2003 01:07 PM
