1995 D15 into 89 STD hatch
sounds like good deal if you had a 92-95 - not so good for the 89 - too many things to change for not much gain - you would have to convert the engine to run OBD0 or convert the car to run OBD1 - the first thing you would need to do is the DPFI to MPFI wiring changes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">sounds like good deal if you had a 92-95 - not so good for the 89 - too many things to change for not much gain - you would have to convert the engine to run OBD0 or convert the car to run OBD1 - the first thing you would need to do is the DPFI to MPFI wiring changes</TD></TR></TABLE>
jlicrx is right to much work for so little power.
But if really want to go for it
jonathan13
Jul 20, 2006 02:35 PM
^Sammy]!.
Feb 29, 2004 06:59 PM
