can i use 90-93 obd0 ls dizzy on 94-01 engine?
Old Mar 4, 2004 | 05:16 AM
firstgenrex's Avatar
Default can i use 90-93 obd0 ls dizzy on 94-01 engine?
hey could i do what the title says? could i use the obd0 dizzy on the 94-01 ls engine? what about on the 94-01 gsr engine? then i could get the obd0 zdyne ecu for it... i dont need an opinion on what i should do... i wanna know if this would work. thanks!
Old Mar 4, 2004 | 05:20 AM
HamiltonRex's Avatar
Default Re: can i use 90-93 obd0 ls dizzy on 94-01 engine? (firstgenrex)
What ECU and what is your car wiried for?
Are you asking if you can run a 94-01 engine on obd0? Yes you can.
I was running a ITR engine on obd0 before i upgraded to obd1, i was using a 1st gen b16 distributor though. Im not too sure which one you will need, i dont know if the mounting points are the same on the b18a/b as they are on the b18c's.
So i dont know if a b18a/b dizzy will bolt to a b18c, look into that.
-Eric
Old Mar 4, 2004 | 11:30 AM
pssshhhh ooop sim really stupid i forgot to mention that. i have an 88 crx si, i dont know what ecu that is. pm6 i think?
Old Mar 4, 2004 | 02:39 PM
Default Re: (firstgenrex)
well you wouldnt be using the stock Crx ecu to power your Gsr engine. Do yourself a favour, convert to obd1, get the proper dizzy and run a chipped p28
I mean you could but it would run like ****.
-Eric
guerosef9
Jul 2, 2007 12:26 PM
honcrx91si
Aug 8, 2005 08:23 PM
p3lon21
Mar 22, 2005 10:03 AM
jahnericm
Mar 8, 2004 02:39 PM
shawn_crx
Oct 3, 2003 07:59 PM
