Prelude '98 oil consumption
Old Mar 4, 2004 | 04:57 AM
ludara's Avatar
Default Prelude '98 oil consumption
It seems my lude is consuming oil at 0.7l/1000 km rate.
I use Castrol RS oil and have 80k miles on engine, which is 2.2VTI(185 hp).
Is it posiblle that piston rings are shot? IT seems too high consumption even for that as I would expect lot of smoke, but there isn't.
Thx
Old Mar 4, 2004 | 12:14 PM
PrecisionH23a's Avatar
Default Re: Prelude '98 oil consumption (ludara)
Sounds like something is definetely wrong. Run the motor with the hose going from the vavle cover to the intake open... if you see white smoke coming from here during idle then usually it is your rings/ringlands going bad.
If you drive REALLY hard and constantly stay in vtec during these 624 miles, it might be normal. It depends how you drive. You may also want to jack your car up and inspect for leaks. The Cam seal would ge a good place to start.
Old Mar 4, 2004 | 12:17 PM
Revi's Avatar
Default Re: Prelude '98 oil consumption (PrecisionH23a)
Have you checked the rubber cap on the left side of the engine up from the distributor? Those are notorious for breaking down and leaking. My leak was minor, it didnt leave oil on the ground, it just seemed to stain the are surrounding it. After i replaced it the oil consumption has gone away. Give it a look.
Kennyjai
Jul 27, 2012 11:02 PM
jdawg916
Apr 10, 2011 03:37 AM
Xringmsp
Jun 15, 2007 05:40 AM
94SuperLudeSI
Jun 10, 2006 05:18 PM
Nomo85
Jun 25, 2005 05:30 AM
